- Phobos
21 Mar 2018 20:30 - 21 Mar 2018 20:32 #68249
by Phobos
Replied by Phobos on topic Jumper T8SG - First TX stock running on Deviation
Looks like they updated the price of T8SG 2.0 on BG to $139, and added some real photos. USB port is accessible on top, it will not get in the way when connected to the PC - I like it!
I'm curious if the gimbals are worth the upgrade from standard... Did any of you get a chance to play with preproduction samples?
Source of the pictures: www.halfchrome.com/jumper-t8sg-plus/
Last edit: 21 Mar 2018 20:32 by Phobos.
- ykev
21 Mar 2018 22:56 - 21 Mar 2018 22:57 #68253
by ykev
Replied by ykev on topic Jumper T8SG - First TX stock running on Deviation
Even the price is higher at BG, please think twice if you buy from geekbuying.com. They don't honor their product if there is anything wrong, even DOA like BG or Gearbest do. Stay away from Geekbuying.com. i made a big mistake because of a coupon code from youtude saving few bucks for the Jumper first gen.
Last edit: 21 Mar 2018 22:57 by ykev.
- Iroquois
22 Mar 2018 01:48 #68257
by Iroquois
Replied by Iroquois on topic Jumper T8SG - First TX stock running on Deviation
Can we assume that the instructions will actually apply to the transmitter and not just Deviation?
- Whiffles
25 Mar 2018 19:28 #68348
by Whiffles
Replied by Whiffles on topic Jumper T8SG - First TX stock running on Deviation
Will a Crossfire micro module work with the new Jumper T8SG Plus? It apparently has a bay for it, but I'm not sure what protocol I'd choose within Deviation.
- glenby
26 Mar 2018 18:43 #68365
by glenby
a few disparate kites
Replied by glenby on topic Jumper T8SG - First TX stock running on Deviation
gearbest after 2 months of pre-order cancelled my order yesterday for the plus.
guess the product is never going to ship - at least from them.
- zarni
26 Mar 2018 21:43 - 26 Mar 2018 21:43 #68366
by zarni
I read of someones pre-order of the new FrSky Tx being canceled by Gearbest a couple of days ago,
So hopefully it's just Gearbest changing their pre-order policy.
Either way though, it's not too cool to just cancel your order with no info..
Replied by zarni on topic Jumper T8SG - First TX stock running on Deviation
glenby wrote: gearbest after 2 months of pre-order cancelled my order yesterday for the plus.
Last edit: 26 Mar 2018 21:43 by zarni. Reason: a letter
29 Mar 2018 14:45 #68406
Replied by vlad_vy on topic Jumper T8SG - First TX stock running on Deviation
It looks like Jumper T8SG V2 will replace T8SG completely. At least at Banggood you can't buy T8SG anymore, but T8SG V2 and T8SG V2 Plus.
- Bug
29 Mar 2018 22:10 - 29 Mar 2018 23:23 #68412
by Bug
Replied by Bug on topic Jumper T8SG - First TX stock running on Deviation
That's bad.
I assume it's cheaper to use just one shell for all.
But the premium appearance of the casing of the original one was really nice.
What's the difference between the channels? Original 10 vs. Version2 12 ?
I wasn't aware.
The v1 controller is replaced by the v2 controller at bang good. The v2 isn't a new article, it's the update of the original v1 product page, so it won't come back.
I wasn't aware.
Last edit: 29 Mar 2018 23:23 by Bug.
- SeByDocKy
08 Apr 2018 07:28 #68550
by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG - First TX stock running on Deviation
Maybe time to open a new thread for the V2 ? and V2 plus ?
- Bug
08 Apr 2018 19:38 #68558
by Bug
I don't really understand why they moved from a good looking futaba copy to a cheap plastic looking copy of the soon to be replaced taranis 9 transmitter and didn't stay with the original design, or at least moved to the design of the new taranis 7s or horus 10s.
But maybe it's just my view.
09 Apr 2018 04:52 - 09 Apr 2018 04:58 #68564
Last edit: 09 Apr 2018 04:58 by vlad_vy.
- Fernandez
09 Apr 2018 06:58 #68571
by Fernandez
Replied by Fernandez on topic Jumper T8SG - First TX stock running on Deviation
Ah Wow !! How are the gimbals, can you check the settling, do the get back to zero ? How is the resolution and precision over the travel, are they accurate, and linear?
Ah especially voice ready and hall gimbal, It may be the tx to replace my devo 7e.
Can you confirm it is possible to use single liion cell and charge over USB? (I have mod my 7e and like it so much, it is perfect, charge it anyware from USB is great.)
- Bug
09 Apr 2018 08:27 #68574
by Bug
Sorry to bother you again vlad, but I've just calculated the screw distance of the gimbals on your photo, and it seems to be the same 35mm as the original gimbals had ?
Can you confirm this or have I estimated the wrong distance of the connector pins?
09 Apr 2018 08:43 #68576
I have not T8SG V2 Plus. It is dc59 images.
- Phobos
09 Apr 2018 13:38 - 09 Apr 2018 13:42 #68577
by Phobos
Seems like it uses switching DC-DC regulator instead of cascaded LDOs, that explains 4.5V minimum input voltage.
Do you know which speaker could fit the mounting bracket?
P42 is uart TX, right? Shame the RX line is not connected (pin 5)...
Looking forward to more details on hall gimbals.
Last edit: 09 Apr 2018 13:42 by Phobos.
- Whiffles
09 Apr 2018 14:58 #68579
by Whiffles
Does the module bay support serial connections?
- Fernandez
10 Apr 2018 08:02 #68599
by Fernandez
There is a topic here on serial out request for external modules, I believe technical should be feasible, but someone has to write add the code, is not yet inside.
- Hr
11 Apr 2018 04:03 #68606
by Hr
Replied by Hr on topic Jumper T8SG -Adding Voice alerts
Hi frends
how to add voice alerts to the T8SG ver 1?
- yets
11 Apr 2018 17:08 #68612
by yets
Replied by yets on topic Jumper T8SG -Adding Voice alerts
Is it safe to assume that Jumper have stopped working on Hall gimbals for Devo series?
- dc59
12 Apr 2018 00:26 #68615
by dc59
Jumper got some problems when they tested hall gimbals on DEVO TX, it will take some more time to solve this.
Replied by dc59 on topic Jumper T8SG -Adding Voice alerts
yets wrote: Is it safe to assume that Jumper have stopped working on Hall gimbals for Devo series?
Time to create page: 0.364 seconds
- Jumper T8SG - First TX stock running on Deviation
