21 Mar 2018 20:30 - 21 Mar 2018 20:32 #68249 by Phobos
Looks like they updated the price of T8SG 2.0 on BG to $139, and added some real photos. USB port is accessible on top, it will not get in the way when connected to the PC - I like it!
I'm curious if the gimbals are worth the upgrade from standard... Did any of you get a chance to play with preproduction samples?
Source of the pictures: www.halfchrome.com/jumper-t8sg-plus/
Last edit: 21 Mar 2018 20:32 by Phobos.
21 Mar 2018 22:56 - 21 Mar 2018 22:57 #68253 by ykev
Even the price is higher at BG, please think twice if you buy from geekbuying.com. They don't honor their product if there is anything wrong, even DOA like BG or Gearbest do. Stay away from Geekbuying.com. i made a big mistake because of a coupon code from youtude saving few bucks for the Jumper first gen.
Last edit: 21 Mar 2018 22:57 by ykev.
22 Mar 2018 01:48 #68257 by Iroquois
Can we assume that the instructions will actually apply to the transmitter and not just Deviation?
25 Mar 2018 19:28 #68348 by Whiffles
Will a Crossfire micro module work with the new Jumper T8SG Plus? It apparently has a bay for it, but I'm not sure what protocol I'd choose within Deviation.
26 Mar 2018 18:43 #68365 by glenby
gearbest after 2 months of pre-order cancelled my order yesterday for the plus.
guess the product is never going to ship - at least from them.
a few disparate kites
26 Mar 2018 21:43 - 26 Mar 2018 21:43 #68366 by zarni
glenby wrote: gearbest after 2 months of pre-order cancelled my order yesterday for the plus.
I read of someones pre-order of the new FrSky Tx being canceled by Gearbest a couple of days ago,
So hopefully it's just Gearbest changing their pre-order policy.
Either way though, it's not too cool to just cancel your order with no info..
Last edit: 26 Mar 2018 21:43 by zarni. Reason: a letter
29 Mar 2018 14:45 #68406 by vlad_vy
It looks like Jumper T8SG V2 will replace T8SG completely. At least at Banggood you can't buy T8SG anymore, but T8SG V2 and T8SG V2 Plus.
29 Mar 2018 22:10 - 29 Mar 2018 23:23 #68412 by Bug
That's bad.
I assume it's cheaper to use just one shell for all.
But the premium appearance of the casing of the original one was really nice.
What's the difference between the channels? Original 10 vs. Version2 12 ?
I wasn't aware.
The v1 controller is replaced by the v2 controller at bang good. The v2 isn't a new article, it's the update of the original v1 product page, so it won't come back.
Last edit: 29 Mar 2018 23:23 by Bug.
08 Apr 2018 07:28 #68550 by SeByDocKy
Maybe time to open a new thread for the V2 ? and V2 plus ?
08 Apr 2018 19:38 #68558 by Bug
I don't really understand why they moved from a good looking futaba copy to a cheap plastic looking copy of the soon to be replaced taranis 9 transmitter and didn't stay with the original design, or at least moved to the design of the new taranis 7s or horus 10s.
But maybe it's just my view.
09 Apr 2018 04:52 - 09 Apr 2018 04:58 #68564 by vlad_vy
Module bay pinout
Placeholders for voice support
www.deviationtx.com/wiki/voiceoutput
Last edit: 09 Apr 2018 04:58 by vlad_vy.
09 Apr 2018 06:58 #68571 by Fernandez
Ah Wow !! How are the gimbals, can you check the settling, do the get back to zero ? How is the resolution and precision over the travel, are they accurate, and linear?
Ah especially voice ready and hall gimbal, It may be the tx to replace my devo 7e.
Can you confirm it is possible to use single liion cell and charge over USB? (I have mod my 7e and like it so much, it is perfect, charge it anyware from USB is great.)
09 Apr 2018 08:27 #68574 by Bug
Sorry to bother you again vlad, but I've just calculated the screw distance of the gimbals on your photo, and it seems to be the same 35mm as the original gimbals had ?
Can you confirm this or have I estimated the wrong distance of the connector pins?
09 Apr 2018 08:43 #68576 by vlad_vy
I have not T8SG V2 Plus. It is dc59 images.
09 Apr 2018 13:38 - 09 Apr 2018 13:42 #68577 by Phobos
Seems like it uses switching DC-DC regulator instead of cascaded LDOs, that explains 4.5V minimum input voltage.
Do you know which speaker could fit the mounting bracket?
P42 is uart TX, right? Shame the RX line is not connected (pin 5)...
Looking forward to more details on hall gimbals.
Last edit: 09 Apr 2018 13:42 by Phobos.
09 Apr 2018 14:58 #68579 by Whiffles
Does the module bay support serial connections?
10 Apr 2018 08:02 #68599 by Fernandez
There is a topic here on serial out request for external modules, I believe technical should be feasible, but someone has to write add the code, is not yet inside.
11 Apr 2018 04:03 #68606 by Hr
Replied by Hr on topic Jumper T8SG -Adding Voice alerts
Hi frends
how to add voice alerts to the T8SG ver 1?
11 Apr 2018 17:08 #68612 by yets
Replied by yets on topic Jumper T8SG -Adding Voice alerts
Is it safe to assume that Jumper have stopped working on Hall gimbals for Devo series?
12 Apr 2018 00:26 #68615 by dc59
Replied by dc59 on topic Jumper T8SG -Adding Voice alerts
yets wrote: Is it safe to assume that Jumper have stopped working on Hall gimbals for Devo series?
Jumper got some problems when they tested hall gimbals on DEVO TX, it will take some more time to solve this.
Time to create page: 1.292 seconds
