12 Apr 2018 00:28 #68617 by dc59
Fernandez wrote: Can you confirm it is possible to use single liion cell and charge over USB? (I have mod my 7e and like it so much, it is perfect, charge it anyware from USB is great.)
Jumper did NOT design charge circuit on PCB , it can't be charged battery via USB port.
12 Apr 2018 00:30 #68618 by dc59
Bug wrote: Sorry to bother you again vlad, but I've just calculated the screw distance of the gimbals on your photo, and it seems to be the same 35mm as the original gimbals had ?
Can you confirm this or have I estimated the wrong distance of the connector pins?
Which distance do you need ? I'm not really understand , could you show me it on picture?
12 Apr 2018 12:34 #68622 by yets
Replied by yets on topic Jumper T8SG -Adding Voice alerts
dc59 wrote:
yets wrote: Is it safe to assume that Jumper have stopped working on Hall gimbals for Devo series?
Jumper got some problems when they tested hall gimbals on DEVO TX, it will take some more time to solve this.
Thanks for the update. It has been quite a few months since they started work on it. I'm sure many would be disappointed if they gave up on it
17 Apr 2018 04:27 - 17 Apr 2018 07:54 #68679 by vlad_vy
Jumper T8SG V2 Plus
I have interchanged switch position for "H" and "B", interchange connectors for "G" and "H" switches, interchange connectors for "A" and "B" switches. Now I have next switch positions:
__H___________A__
D___G______C___B
SWH = HOLD/RUD DR
SWG = GEAR
SWA = FMODE
SWB = AIL DR
SWC = MIX
SWD = ELE DR
Also, changed switch mapping at "capabilities.h":
#ifdef UNDEF_INP
#define INP_RUD_DR0 INP_SWH0
#define INP_RUD_DR1 INP_SWH1
#define INP_ELE_DR0 INP_SWD0
#define INP_ELE_DR1 INP_SWD1
#define INP_AIL_DR0 INP_SWB0
#define INP_AIL_DR1 INP_SWB1
#define INP_FMOD2  INP_SWA2
#define INP_MIX0   INP_SWC0
#define INP_MIX1   INP_SWC1
#define INP_MIX2   INP_SWC2
#define INP_GEAR0  INP_SWG0
#define INP_GEAR1  INP_SWG1
#endif
#ifdef CHANMAP
//These are legacy mappings
  CHANMAP("DR",     SWB1)
  CHANMAP("RUD DR", SWH1)
  CHANMAP("ELE_DR", SWD1)
  CHANMAP("AIL_DR", SWB1)
  CHANMAP("GEAR",   SWG1)
//Current mappings
  CHANMAP("DR0", SWB0)
  CHANMAP("DR1", SWB1)
  CHANMAP("RUD DR0", SWH0)
  CHANMAP("RUD DR1", SWH1)
  CHANMAP("ELE DR0", SWD0)
  CHANMAP("ELE DR1", SWD1)
  CHANMAP("AIL DR0", SWB0)
  CHANMAP("AIL DR1", SWB1)
  CHANMAP("HOLD0", SWH0)
  CHANMAP("HOLD1", SWH1)
  CHANMAP("FMODE0", SWA0)
  CHANMAP("FMODE1", SWA1)
  CHANMAP("FMODE2", SWA2)
  CHANMAP("MIX0", SWC0)
  CHANMAP("MIX1", SWC1)
  CHANMAP("MIX2", SWC2)
  CHANMAP("GEAR0", SWG0)
  CHANMAP("GEAR1", SWG1)
#endif
Now I can import all models from devo8 without any changes. With one exception, I need manually correct 2-pos to 3-pos switch mapping: for example change "SW D1" (ELE DR1) to "!SW D0".
Last edit: 17 Apr 2018 07:54 by vlad_vy.
17 Apr 2018 13:21 #68688 by vlad_vy
Jumper T8SG V2 Plus - RF power output at antenna connector
I don't understand why "T8SG V2 Plus" RF power output is twice higher than with other 4in1 modules (I have four modules).
Devo 8s (4in1 module) - Jumper T8SG V2 Plus (4in1 module)
Protocol Devo (CYRF6936)
150mW = 74.38mW = 142.95mW
100mW = 63.10mW = 121.96mW
30mW = 33.77mW = 65.21mW
10mW = 8.48mW = 19.57mW
3mW = 3.27mW = 8.48mW
1mW = 880uW = 2.95mW
300uW = 180uW = 750uW
100uW = 50uW = 240uW
Protocol Hubsan4 (A7105)
150mW = 79.43mW = 142.95mW
100mW = 79.43mW = 142.95mW
30mW = 76.86mW = 132.04mW
10mW = 53.53mW = 45.41mW
3mW = 20.21mW = 18.36mW
1mW = 6.52mW = 5.18mW
300uW = 3.61mW = 2.75mW
100uW = 1.63mW = 1.28mW
Protocol S-FHSS (CC2500)
150mW = 57.17mW = 108.26mW
100mW = 51.79mW = 93.63mW
30mW = 14.22mW = 38.52mW
10mW = 4.25mW = 12.92mW
3mW = 1.28mW = 4.54mW
1mW = 0.38mW = 1.42mW
300uW = 0.16mW = 0.33mW
100uW = 0.05mW = 0.11mw
Protocol SymaX (NRF24L01)
150mW = 79.43mW = 148.74mW
100mW = 79.43mW = 148.74mW
30mW = 76.86mW = 148.74mW
10mW = 63.10mW = 121.96mW
3mW = 63.10mW = 121.96mW
1mW = 20.21mW = 38.52mW
300uW = 20.21mW = 38.52mW
100uW = 20.21mW = 38.52mW
17 Apr 2018 14:32 #68691 by Bug
Just the distance of the screws of the gimbal, if there is a chance to fit them into the v1 version of the transmitter. Frsky gimbals are great and rather cheap to get, but way too big be fitted into a jumper.
17 Apr 2018 17:51 - 17 Apr 2018 17:53 #68695 by vlad_vy
Warning!!!
With "Jumper T8SG V2 Plus" there is RF noise to Hall sensor wires problem. It depends from used protocol and output power. The simple solution is to unplug wires, twist the wires to protect them from electromagnetic interference and plug them back in.
Last edit: 17 Apr 2018 17:53 by vlad_vy.
17 Apr 2018 18:43 - 17 Apr 2018 18:47 #68698 by Fernandez
For the extra power, some ideas, you could check:
Higher voltage, at the PA/LNA chip, better matching between antenna and module, or on the module itself. (the first modules had a long open trace) Only think i do not like so much there is no ceramic BPF filter at the output of the module.....
With regards to RFI, I do not like at all, open pins to the CPU without any filtering. We could surely add 100pf capacitor on all input lines, switches and adc pots input at the pcp, to gnd. Best design would have those capcitors close to the CPU. When using lower frequency UHF modules at 1watt , the pick up will even be worse....(I doubt the radio could have CE with this problem...)
Other easy solution, to make a bit more robust against RFI, we could possible add some ferrite rings or ferrite clamps around the hall cables and switches.
www.ebay.ie/itm/5X-3-5mm-Noise-Suppresso...ack-MW-/192382534342
Last edit: 17 Apr 2018 18:47 by Fernandez.
18 Apr 2018 04:11 #68708 by vlad_vy
If Jumper use Devo 7e diagram for T8SG, it has RC filters (100Ohm + 100pF) at ADC inputs. At least, twisting wires completely fix the problem for user that note this problem.
18 Apr 2018 14:40 #68718 by vlad_vy
35x42mm
23 Apr 2018 23:27 - 23 Apr 2018 23:48 #68817 by Philipp
vlad_vy wrote: If Jumper use Devo 7e diagram for T8SG, it has RC filters (100Ohm + 100pF) at ADC inputs. At least, twisting wires completely fix the problem for user that note this problem.
Twisting the wires did not fix the problem for me, there was still some jitter on the gimbal channels (Ch 1 - 4, +/- 12 around center). In my case the batteries were partially depleted and not in the best shape.
After switching them out for fully charged, high quality ones the jitter was gone. Interestingly i could only notice jitter when using the CC2500 module / the FrSky protocol. The hall sensors seem to be very sensitive to fluctuations in the battery voltage.
I've attached some pictures of the exterior and interior of the T8SG V2 Plus.
I really like the included JR module case. Please note that I've added the RP-SMA pigtail, it is not included with the case.
Since the multimodule already supports all protocols I need, I've exchanged the empty module for the black blanking plate which was included with my original Taranis X9E ( alofthobbies.com/frsky-taranis-module-cover.html or maybe www.banggood.com/Transmitter-Module-Case...rch&cur_warehouse=CN ):
I've also made a quick five minute video with my initial thoughts about the T8SG V2 Plus:
Last edit: 23 Apr 2018 23:48 by Philipp. Reason: Tried to resize attached images
24 Apr 2018 05:04 #68820 by vlad_vy
I have voltage jitter at the Devo8 screen with some protocols and old 4xAA battery, with fresh 4xAA battery the jitter is gone.
24 Apr 2018 17:26 #68824 by Phobos
Would a capacitor on hall sensor power rails help to reduce the jitter?
24 Apr 2018 17:33 - 24 Apr 2018 17:41 #68825 by vlad_vy
They all connected to 3.3V and ground.
With 4xAA battery you are very close to the edge of LDO capabilities (dropout voltage): 4.8V - 3.3V = 0.5V
Last edit: 24 Apr 2018 17:41 by vlad_vy.
24 Apr 2018 19:15 #68831 by Philipp
vlad_vy wrote: They all connected to 3.3V and ground.
A 2s LiFe with 6.6V nominal and a relatively flat discharge curve might be a better option, or do you think that heat dissipation in the LDO would be too high?
According to the BG description, a 2S LiPo may be used, so it should be fine?
25 Apr 2018 04:07 #68849 by vlad_vy
I use 2S LiPo without problems.
25 Apr 2018 12:55 #68860 by dc59
2S LiPo batteries are best choice for Jumper T8SG V2 / V2 plus.
please take a look at this post
25 Apr 2018 18:12 #68861 by Fernandez
Could you verify and readout the battery voltage displayed at the tx screen? Is this steady and stable? My 7e I have this fluctuating, at some protocols such as Frsky.
I did a lot of testing, but can't put my finger on the cause. At least it is not caused by the Tx internal regulator, as replaced an tested with adding large capacitors at 3v3rail, neither by noise at the ADC pin for Txbat sense (also adding capacitors).
Just wondering if same issue is also in jumper..
26 Apr 2018 00:10 #68864 by dc59
More power test update to this post
30 Apr 2018 05:58 #68932 by Iroquois
Did it not occur to all those helping Jumper with development that two of the switchs on the front of all models should have longer toggles to differentiate them? Didn't it occur that the two switches on the top of the V2 and plus models would be better as push switches to operate functions on toy quads? If the green LED indicates RF, why does it go on and off at will?
There is no such thing as a 'hall effect gimbal'. A gimbal is a gimbal and can operate a conventional potentiometer or a hall effect sensor. If your conventional pot has problems centering, you simply need to excercise it a few times.
Time to create page: 0.557 seconds
