what protocol to use for walkera master cp on the
- Firebug
28 Aug 2017 03:54 #64002
by Firebug
what protocol to use for walkera master cp on the was created by Firebug
Hey guys,
Can anyone please help? I recently purchased a rx701 receiver for my walkera master cp. I have a devo 7e with deviation but is anyone able to tell me what protocol to set the tx on so i can bind to the receiver please ?
28 Aug 2017 04:43 #64004
Replied by vlad_vy on topic what protocol to use for walkera master cp on the
"Devo" protocol.
- Firebug
28 Aug 2017 23:34 #64007
by Firebug
Replied by Firebug on topic what protocol to use for walkera master cp on the
Thanks mate,
I bought a new receiver and was told to buy this one by hobbyking i purchased the RX701 for my master cp. Is there a way to find out if my devo 7e will bind to this receiver? Ive tried what the videos say to do but I'm not sure if i'm missing a step or if it just wont bind?
- RoGuE_StreaK
28 Aug 2017 23:48 #64008
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic what protocol to use for walkera master cp on the
The RX701 is a Walkera Devo receiver, the Devo range of TXs were specifically made for this protocol so yes it will work; if it doesn't, there are other issues.
Which videos? There may be differences in binding when setting up via deviation, or maybe the old bind needs to be cleared (haven't worked with a devo receiver in a long time)
The built-in transmitter chip in the Devo 7E is the CYRF6936, which can handle Devo, DSM2, and DSMX (and a couple of other odd ones).
- Firebug
29 Aug 2017 00:36 #64009
by Firebug
its behaving really strange. I have re built the whole heli so everything basically is brand new including servos and motors. Ive got it to bind but i cant get the elev servo to respond to throttle input and now when i plug the motor back in the main blades want to spin even with the throttle completely down. I'm starting to think its settings in the tx i need to change but i dont know what to do from here.
- Deal57
29 Aug 2017 22:08 #64022
by Deal57
Replied by Deal57 on topic what protocol to use for walkera master cp on the
Yeah, important thing to remember is to remove blades before tinkering with receivers
We've all been there.
Are you building your own model in the TX or are you using a model.ini that you downloaded? If you are using one you downloaded, please post it here so we can review it. If you are using the TX to build a model, it's a bit daunting first time, but not too hard. In the Model Setup, File button (starts out saying "<Load>"), you can use right arrow to scroll to the Template.. option and load the 6-channel heli template. Your mixers should be set to basic defaults at that point.
Check out Tom Z's model.ini file and documentation at this thread .
Let us know how it goes.
Time to create page: 0.430 seconds
- what protocol to use for walkera master cp on the
