7E gimbal suddenly not centering anymore
- Arakon
22 Sep 2017 04:28 #64579
by Arakon
7E gimbal suddenly not centering anymore was created by Arakon
Moin.
As of my last flight, my right gimbal is no longer centering right. The stick itself does, but the center point varies wildly from 1500-1420, and drifts even at rest. I'm going to guess it's the potentiometer.
Anyone know of a fitting replacement?
22 Sep 2017 04:43 #64580
Replied by vlad_vy on topic 7E gimbal suddenly not centering anymore
First, try to remove play between pot axle and gimbal.
www.deviationtx.com/forum/6-general-disc...entering-issue#60932
- Arakon
22 Sep 2017 07:34 #64587
by Arakon
Replied by Arakon on topic 7E gimbal suddenly not centering anymore
Mine actively drifts, so I don't think it's just physical play.. also, I seem to recall that I did that mod before.
I ordered a Taranis Q X7 and the hall gimbals now.. I still have an ultimate 7E sitting here, though. We'll see if I can live with the huge size of the Taranis.
- aMax
22 Sep 2017 10:17 - 22 Sep 2017 10:20 #64592
by aMax
Replied by aMax on topic 7E gimbal suddenly not centering anymore
My 7e has this now on one pot. Luckily it is only a small gap, subtrim only gives me 1501 or to the other side 1496.
I take this 1501 output with a deathband of 2.
@ Arakon
After a while you will prefere the Q X7, belief me.
@ Arakon
Last edit: 22 Sep 2017 10:20 by aMax.
- Arakon
30 Sep 2017 22:43 #64753
by Arakon
Okayyy.. wth.
After replacing the gimbal, it suddenly started drifting AGAIN. This can't be down to the gimbal itself. There's no way two known good gimbals, one being nearly new, start drifting in exactly the same manner suddenly. Could something on the board be going bad?
01 Oct 2017 04:57 #64755
Replied by FDR on topic 7E gimbal suddenly not centering anymore
Check the connectors, one wire might be broken...
- Arakon
01 Oct 2017 05:18 #64756
by Arakon
The wires were replaced along with the actual gimbal.
01 Oct 2017 05:37 #64757
It means nothing, a new connector can be broken too...
Time to create page: 0.172 seconds
- 7E gimbal suddenly not centering anymore
