Bind Devo 7e with Walkera furious 215
24 Sep 2017 21:49 #64632 by MarTn
Hey there,
I received my new FURIOUS 215, it's my first no RTF drone and i need some help:
I flashed my Devo 7e to deviationTX and when i try to bind my furious 215 it does not do anything, i chose "DEVO" as protocol but when i press "bind" it search for 15 sec but does not find it.
The drone continue to beep, nothing more.
I saw under the bind button i have "fixed ID" with 123456, it should update by itself when the drone and tx will be bind right?
No problem with the stock firmware, it bind it at startup.
I'm sure i missed some information somewhere but i dont know where. :(
25 Sep 2017 06:18 #64643 by FDR
Replied by FDR on topic Bind Devo 7e with Walkera furious 215
Clear the fixed ID, power off both the TX and the quad, turn on the TX, and immediately power on the quad.
Wait for the auto bind to finish, and it's done.
However it is recommended to use a fixed ID, so go into the model setup menu, write in some random fixed ID, and press bind.
After that you can turn on the TX and the model in any sequence, they will be bound...
25 Sep 2017 21:47 #64667 by MarTn
Replied by MarTn on topic Bind Devo 7e with Walkera furious 215
It worked, thanks alot.
Time to create page: 0.507 seconds
