DEVO 7E - No response on HOLD and FMOD switches.
  • Akmal2017
  • Akmal2017's Avatar Topic Author
  • luv this hobby!!
06 Oct 2017 03:24 #64860 by Akmal2017
Hi everyone,
im new to the hobby. Its been 4 days since ive received my first quad, QX95 with F3 Evo brush FC and Devo7E.
Currently my problem is I cant get the switches to work on Betaflight but in the transmitter (under "stick input') there's movement when flipping switches.
All other 4 channels work on Beta flight except these two.
I want to use the switches to arm/disarm my motors.
Just so you know, the motors spin when i move the sliders in betaflight but will not move when i use the throttle sticks .
Appreciate your help guys.
08 Oct 2017 11:27 #64912 by Deal57
You need to assign your switches to the channels. For my tiny quads, I use channel 5 to arm, and in Devo, that means setting up a switch (like Hold) in the Model menu, mixer. On the channel 5-HOLD, change to a simple curve, assign SRC Hold0. On the channel CH6, change to a simple curve with SRC FMODE0. I suggest you test with the props removed.
Search for Cleanflight or betaflight model.ini files for more ideas.
The manual section 9.2 (available from the left side menu on this page) goes into more detail but this should get you flying.
08 Oct 2017 11:35 #64913 by Akmal Noor
Replied by Akmal Noor on topic DEVO 7E - No response on HOLD and FMOD switches.
Hi Deal57, thnx for the info.
I manage to find a video to fix the issue.
Like you said, assign the switches to the channels.
Time to create page: 0.072 seconds
