Difference between 7E 256 and Devo 7E
07 Oct 2017 19:40 #64901 by C0ckpitvue 777
Difference between 7E 256 and Devo 7E was created by C0ckpitvue 777
Hello all this might be very novice like,I haven't been around the deviation community in a sec.Trying to distinguish the difference between 7e 2 versions in the file as I would like to update the latest nightlies but not sure which 1 to use.Is the plain 7E files for the ultimate version and the 256 version for the original?Thanks in advance,all feedback is greatly appreciated.
07 Oct 2017 20:18 #64904 by victzh
Replied by victzh on topic Difference between 7E 256 and Devo 7E
Devo7E-256 is the build for Devo 7E with MCU replaced for more capable STM32F103RC - it has 256K flash ROM, thus the name. If you didn't do this to your Devo, use plain 7E files. Add-on switches are in any code branch, they should be activated through hardware.ini file.
07 Oct 2017 20:37 #64905 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Difference between 7E 256 and Devo 7E
Thank you very much.
Time to create page: 0.049 seconds
