Firmware 5.0
10 Oct 2017 04:58 #64944 by unclecrash
Firmware 5.0 was created by unclecrash
Hi guy's been a while , but just pulled out my devo 12s and installed the new 5.0 firmware. seems I might be missing some stuff not sure, In my e drive I have language,layout.modelico,models,template,datalog,debug devo12 4.0, errors, tx,hardware. I dont see no files for media bmp,mediafont, media sound, and media config. did I do something wrong ? Another thing a guy on rcgroups is asking about the test screen on his devo 12s he says he has no test range page I told him either did I and I believe it got left behind somehow . His is stock firmware from walkera and I could of swore it had a test range page on the stock version am I correct on this . As I know as soon as I got the version 5 firmware in mine I got the test page back along with a scanner page and was also wondering whart this does Thanks UC
10 Oct 2017 05:04 - 10 Oct 2017 05:12 #64945 by vlad_vy
Replied by vlad_vy on topic Firmware 5.0
For Devo 12s the media files moved to library file due to limited flash memory size.
For custom "config.ini", "sound.ini", and "toggle3.bmp" you can create "mymedia" folder. But, it will work only with "Deviation v5.0.0 build with latest protocols" with latest protocols and fixes. Or you can use Nightly Builds.
www.deviationtx.com/forum/builds/6407-de...ith-latest-protocols
Last edit: 10 Oct 2017 05:12 by vlad_vy.
10 Oct 2017 06:18 #64947 by FDR
Replied by FDR on topic Firmware 5.0
AFAIK the stock Walkera devention firmwares doesn't have built in range test function.
You can however lower the output power to 300uW or 1mW, check the range and then calculate the estimated full power range just like a range test would...
12 Oct 2017 02:04 - 12 Oct 2017 02:08 #64971 by unclecrash
Replied by unclecrash on topic Firmware 5.0
Vlad so i got to build the library like in PB's thread? Did I mess up loading 5.0 from the download page. I see you directed me to the latest protocols where I think I should have downloaded 5.0 ,but I had already downloaded off of the downloads page. Seems my clocks are stuck had this problem back a few years ago noticed they are still in 2012 every time I reset them the go back to 2012 and the date and time. I thought I read where 5.0 took care of this?
Last edit: 12 Oct 2017 02:08 by unclecrash.
12 Oct 2017 02:10 #64972 by unclecrash
FDR thanks for clearing that up. I passed the info on to the the guy.
12 Oct 2017 04:59 #64974 by vlad_vy
Devo 12s clock work on tablet battery. You need change clock battery, open the cover under Tx battery.
12 Oct 2017 05:12 #64975 by unclecrash
Thanks Vlad
Time to create page: 0.197 seconds
