help me please....
03 Nov 2017 00:46 #65449 by arie
help me please.... was created by arie
today received new devo 7e, then I installing extra switch 3x2 after that upgraded to deviation 5,0 already follows instruction but the problem after upgrade to deviation I cant entering to menu all button only beep without any happened need help please.......
03 Nov 2017 01:01 #65450 by jakerock
Replied by jakerock on topic help me please....
Did you copy over the new 5.0 files and folders to the devo in USB mode?
03 Nov 2017 01:43 #65451 by arie
Replied by arie on topic help me please....
yesss all copied
03 Nov 2017 06:13 #65453 by Gerry
Replied by Gerry on topic help me please....
Did you format usb drive before copying files?
Did you safely eject/remove hardware after copying files?
Are you sure you used Devo 7e file, not emulator file?
did you use dfuse 2.31?
FFS (Forever Fixing Stuff)
03 Nov 2017 07:18 #65454 by arie
Did you format usb drive before copying files? YES I DID
Did you safely eject/remove hardware after copying files? YES I DID
Are you sure you used Devo 7e file, not emulator file? YES I USE DEVO 7E FILE
did you use dfuse 2.31? NO I DID I USE 4, 1 IF I AM NOT WRONG
03 Nov 2017 07:33 #65455 by vlad_vy
Replied by vlad_vy on topic help me please....
Are you sure of correct polarity of diodes connection?
03 Nov 2017 08:20 #65456 by arie
ok i will test to take off all switch wirring first if that can be solve
Time to create page: 0.109 seconds
