help me please....
- arie
03 Nov 2017 00:46 #65449
by arie
help me please.... was created by arie
today received new devo 7e, then I installing extra switch 3x2 after that upgraded to deviation 5,0 already follows instruction but the problem after upgrade to deviation I cant entering to menu all button only beep without any happened need help please.......
- jakerock
03 Nov 2017 01:01 #65450
by jakerock
Replied by jakerock on topic help me please....
Did you copy over the new 5.0 files and folders to the devo in USB mode?
- arie
- Gerry
- Bbrad
03 Nov 2017 06:13 #65453
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic help me please....
Did you format usb drive before copying files?
Did you safely eject/remove hardware after copying files?
Are you sure you used Devo 7e file, not emulator file?
did you use dfuse 2.31?
- arie
03 Nov 2017 07:18 #65454
by arie
Replied by arie on topic help me please....
Did you format usb drive before copying files? YES I DID
Did you safely eject/remove hardware after copying files? YES I DID
Are you sure you used Devo 7e file, not emulator file? YES I USE DEVO 7E FILE
did you use dfuse 2.31? NO I DID I USE 4, 1 IF I AM NOT WRONG
03 Nov 2017 07:33 #65455
Replied by vlad_vy on topic help me please....
Are you sure of correct polarity of diodes connection?
- arie
03 Nov 2017 08:20 #65456
by arie
ok i will test to take off all switch wirring first if that can be solve
- help me please....
