How to hack Code?
- C0ckpitvue 777
23 Nov 2017 20:39 - 23 Nov 2017 20:39 #66110
by C0ckpitvue 777
How to hack Code? was created by C0ckpitvue 777
First of all happy thanksgiving to you all and may God bless you all richly.I wanted to know if there is a tutorial online any where that has a tutorial on hacking protocol codes for deviation,this is something I would like to get into and contribute.Thanks in advance.
Last edit: 23 Nov 2017 20:39 by C0ckpitvue 777.
- RoGuE_StreaK
24 Nov 2017 11:49 #66127
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic How to hack Code?
www.deviationtx.com/forum/protocol-devel...95-spi-capture-guide
might be a starting point
- C0ckpitvue 777
24 Nov 2017 15:48 - 24 Nov 2017 15:49 #66133
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic How to hack Code?
Thank you,I know how to take captures maybe this will help me grab the concept and comprehend the ins and outs.
Last edit: 24 Nov 2017 15:49 by C0ckpitvue 777.
- Moeder
24 Nov 2017 19:49 #66135
by Moeder
Replied by Moeder on topic How to hack Code?
The really really really short summary:
Step 1) read up spi basics
Step 2) setup spi analyzer in saleae logic and export hex to text file
Step 3) run the hex file through the format spi perl script provided in the deviating repository utils directory
Step 4) check the perl scripts output and see what happens in data packets and how rf channels are changed.
Step 5) if you know how packets look and how/what channels are hopped through, take a look at the timing of the protocol
- C0ckpitvue 777
24 Nov 2017 20:33 #66144
by C0ckpitvue 777
Thank you,so basically it's deciphering and pattern recognition.I will definitely to my homework.
- Moeder
25 Nov 2017 07:47 #66151
by Moeder
Yup. Also look at existing protocols for the same module, many are just variants of others.
- C0ckpitvue 777
26 Nov 2017 09:33 #66177
by C0ckpitvue 777
Thank you,can you link me to the format spi perl script in the deviating repositary or tell me which folder it's in on the downloads page please.thanks again.
- Moeder
26 Nov 2017 19:22 - 26 Nov 2017 19:22 #66182
by Moeder
It is in the folder utils/spi of the deviation repository. Clone it or download the entire repository, as the perl script also uses other files from the repository.
Last edit: 26 Nov 2017 19:22 by Moeder.
- C0ckpitvue 777
26 Nov 2017 23:24 #66185
by C0ckpitvue 777
Thanks.I wanted to know do I export the hex to text with the default export settings with csv.I'm also still trying to find the deviation repository.
- C0ckpitvue 777
28 Nov 2017 01:42 #66220
by C0ckpitvue 777
Thank you.
06 Dec 2017 01:37 #66358
Replied by hexfet on topic How to hack Code?
There's a couple good
stickied posts here
too.
Maybe take a look at the hubsan protocol as a starting point for a bugs3 implementation.
- C0ckpitvue 777
06 Dec 2017 01:48 #66359
by C0ckpitvue 777
Thank you hexfet,I ain't even get started understanding the basic concept yet,I am so consumed at my job right now I haven't really had time to read up on hacks yet.I can take captures and truly hope this bugs 3 gets implemented.If I can help with any equipment to help get this implemented,I will gladly contribute.
Time to create page: 0.163 seconds
- How to hack Code?
