How to hack Code?
23 Nov 2017 20:39 - 23 Nov 2017 20:39 #66110 by C0ckpitvue 777
How to hack Code? was created by C0ckpitvue 777
First of all happy thanksgiving to you all and may God bless you all richly.I wanted to know if there is a tutorial online any where that has a tutorial on hacking protocol codes for deviation,this is something I would like to get into and contribute.Thanks in advance.
Last edit: 23 Nov 2017 20:39 by C0ckpitvue 777.
24 Nov 2017 11:49 #66127 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic How to hack Code?
24 Nov 2017 15:48 - 24 Nov 2017 15:49 #66133 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic How to hack Code?
Thank you,I know how to take captures maybe this will help me grab the concept and comprehend the ins and outs.
Last edit: 24 Nov 2017 15:49 by C0ckpitvue 777.
24 Nov 2017 19:49 #66135 by Moeder
Replied by Moeder on topic How to hack Code?
The really really really short summary:
Step 1) read up spi basics
Step 2) setup spi analyzer in saleae logic and export hex to text file
Step 3) run the hex file through the format spi perl script provided in the deviating repository utils directory
Step 4) check the perl scripts output and see what happens in data packets and how rf channels are changed.
Step 5) if you know how packets look and how/what channels are hopped through, take a look at the timing of the protocol
24 Nov 2017 20:33 #66144 by C0ckpitvue 777
Thank you,so basically it's deciphering and pattern recognition.I will definitely to my homework.
25 Nov 2017 07:47 #66151 by Moeder
Yup. Also look at existing protocols for the same module, many are just variants of others.
26 Nov 2017 09:33 #66177 by C0ckpitvue 777
Thank you,can you link me to the format spi perl script in the deviating repositary or tell me which folder it's in on the downloads page please.thanks again.
26 Nov 2017 19:22 - 26 Nov 2017 19:22 #66182 by Moeder
It is in the folder utils/spi of the deviation repository. Clone it or download the entire repository, as the perl script also uses other files from the repository.
Last edit: 26 Nov 2017 19:22 by Moeder.
26 Nov 2017 23:24 #66185 by C0ckpitvue 777
Thanks.I wanted to know do I export the hex to text with the default export settings with csv.I'm also still trying to find the deviation repository.
27 Nov 2017 04:54 #66189 by FDR
28 Nov 2017 01:42 #66220 by C0ckpitvue 777
Thank you.
06 Dec 2017 01:37 #66358 by hexfet
Replied by hexfet on topic How to hack Code?
There's a couple good stickied posts here too.
Maybe take a look at the hubsan protocol as a starting point for a bugs3 implementation.
06 Dec 2017 01:48 #66359 by C0ckpitvue 777
Thank you hexfet,I ain't even get started understanding the basic concept yet,I am so consumed at my job right now I haven't really had time to read up on hacks yet.I can take captures and truly hope this bugs 3 gets implemented.If I can help with any equipment to help get this implemented,I will gladly contribute.
Time to create page: 0.294 seconds
