CC2500 Installation questions
24 Nov 2017 08:06 #66119 by Danker16
CC2500 Installation questions was created by Danker16
I installed a CC2500 in my devo 10, however I was curious if module placement in the transmitter as well as the coax cable length to the antenna were cruicial?
if it it any optimal position and cable length?, right now I have a very short cable and the module taped on top of the stock CRYF module.
thanks,
Jo
25 Nov 2017 20:24 #66165 by hexfet
Replied by hexfet on topic CC2500 Installation questions
The module placement is not critical. The antenna should be away from any metal pieces. If it's long enough try to snake it up the existing mast or across the inside top of the case.
Time to create page: 0.390 seconds
