Devo12s not working correctly SOLVED
- magic_marty
03 Dec 2017 20:34 - 03 Dec 2017 23:59 #66326
by magic_marty
Devo12s not working correctly SOLVED was created by magic_marty
My 12s not powering up correctly anymore it reset the internal battery voltage alarm and i have no stick inputs on the sliders. Also it always goes to the last model in the menu..Then if i try to view the input menu it wont let me select it and it reboots..I have tried different battery and it still does the same thing..Last thing i modded was i hooked up a wireless trainer rx i soldered directly to the battery pins inside the tx and the tip connector on the DSC port it worked no problems ..When i plugged in the rx it powered up like it should ...other mods are the M9 gimbals and the voice alerts Dfplayer..
Any help would be greatly appreciated..
Here is what the erros txt file has..
[Soft fault]
devo12-v5.0.0-4413a98
R0 = 0002888a
R1 = 20008226
R2 = 00000000
R3 = 200080f8
R12 = 20000324
LR [R14] (subroutine call return address) = 0800b4a1
PC [R15] (program counter) = 08005dc8
PSR = 01000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
SCB_SHCSR = 00000000
Top of Stack:2000c000
Stack Detect:2000bfc8
Backtrace:
[Soft fault]
R0 = 0002888a
R1 = 20008226
R2 = 00000000
R3 = 200080f8
R12 = 20000324
PSR = 01000000
BFAR = e000ed38
CFSR = 00000000
HFSR = 00000000
DFSR = 00000000
AFSR = 00000000
Backtrace:
Last edit: 03 Dec 2017 23:59 by magic_marty.
- magic_marty
04 Dec 2017 00:00 #66327
by magic_marty
Replied by magic_marty on topic Devo12s not working correctly SOLVED
I think what happened is the external rx drained the battery to low and it corrupted the file system.. I formatted and loaded up my last backup i created and everything seems to be working as should now..
Time to create page: 0.714 seconds
- Devo12s not working correctly SOLVED
