Binding procedure for XK K110
14 Dec 2017 01:11 #66492 by harmony96
Binding procedure for XK K110 was created by harmony96
I tried to bind my XK K110 to devo 8s, but failed.
CC2500 module is successfully installed in my devo 8s a few years ago.
My devo 8s has successfully bound skyartec protocol for many years.
But, it could not bind the XK K110.
I ordered three of XK K110,
So, XK K110s may have no problem.
What I did is as follows.
#1
1. Turn on a transmitter. (protocol is set to S-FHSS, Fixed ID: None)
2. Turn on K110 and red led is flashing.
3. push a bind button for 1 sec. Then, the flashing red led is stopped.
4. wait..... wait.. wait... nothing happened.
#2
1. Turn on a transmitter. (protocol is set to S-FHSS, Fixed ID: Assign some number)
4. Push a Re-Init button in devo 8s
5. wait..... wait.. wait... nothing happened.
#3
1. Turn on K110 and red led is flashing.
2. push a bind button for 1 sec. Then, the flashing red led is stopped.
3. Turn on a transmitter. (protocol is set to S-FHSS, Fixed ID: None)
#4
3. Turn on a transmitter. (protocol is set to S-FHSS, Fixed ID: Assign some number)
15 Dec 2017 23:43 #66518 by Deal57
Replied by Deal57 on topic Binding procedure for XK K110
The bind process seems to work best at lower power, and with maybe a meter between the tx and RX. I have two birds using this, and I to adjust the freq-fine when choosing between them. The process is detailed in this rather long thread, and worth the read.
XK K110 Protocol
