- Alvarez
24 Feb 2018 14:15 #67740
by Alvarez
Replied by Alvarez on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
How do you do that?
- IKKI
24 Feb 2018 14:20 #67741
by IKKI
Replied by IKKI on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I have not done anything yet. I arrived today and I did the first range tests. Very poor compared to my 10 o'clock. But aesthetically I like the idea of a fpv screen positioned above.
- WimH
24 Feb 2018 17:02 #67742
by WimH
Replied by WimH on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Just got mine today.Knobs for the top pots missing.... Flashed the latest software without problems and after that the return to neutral does not seem too bad with mine . Hope range is OK too... But one problem, when I turn it on after installing latest software it says CYRF6936 chip is missing??? All protocols using this one are marked with a * ???
24 Feb 2018 17:36 #67744
Replied by vlad_vy on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I don't understand how it possible. Can you provide original "hardware.ini" file?
- WimH
25 Feb 2018 11:48 - 25 Feb 2018 11:49 #67761
by WimH
If you mean before update, no. This is the one I have now
vlad_vy wrote: I don't understand how it possible. Can you provide original "hardware.ini" file?
Last edit: 25 Feb 2018 11:49 by WimH.
25 Feb 2018 11:58 #67762
It's standard "hardware.ini". It doesn't help to understand why after installing latest software it says CYRF6936 chip is missing.
- WimH
25 Feb 2018 12:05 #67763
by WimH
it gets weirder... After I started the TX in USB mode to copy the file and also opened it to check the contents, the error is gone, startup is normal now???
25 Feb 2018 13:12 - 25 Feb 2018 13:12 #67764
Probably something is wrong with filesystem. Try to format USB drive, write filesystem and use "Safely Remove Hardware".
Last edit: 25 Feb 2018 13:12 by vlad_vy.
- IKKI
02 Mar 2018 21:25 #67860
by IKKI
Guys, but have you done range tests? With the NRF24L01 module I have 1/3 compared to my I have 10 and with the protocols Dsm is something ridiculous ... Worse than I have 7. Without long range mod. Do yours go better?
- nille
03 Mar 2018 13:53 #67881
by nille
Replied by nille on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I sent my TX back to banggood. Banggood will reimburse me for the cost of the shipment and the purchase price.
- plmask
07 Mar 2018 12:11 #67955
by plmask
Replied by plmask on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
The iRangeX iRX-IR8M failure is now complete. The hardware design, manufacture, distribution and service was not up to the lowest basic requirements and expectations of an RC community that has been around for more than 50 years. Banggood's failure to openly acknowledge the concerns of it's customers and actively suppressing negative comments on their website sends a clear message, you can't trust them to do the right thing for customers.
- GabrielRB
09 Mar 2018 18:32 #67982
by GabrielRB
Replied by GabrielRB on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
I tested with two frsky receivers D8RII and D8RXP. At 100uW I achieve 50m without problems, It can reach 60m I believe....
At 150mW it is 1500x bigger than 100uW so theoretically distance will increase by 38x given to us ~1,9km. But again, theoretically.
- wdlee
10 Mar 2018 10:23 #67994
by wdlee
Replied by wdlee on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hi.
I connected the trainer port and tried to connect the vibration motor.
Fortunately, it was successful.
This unit has a universal vibration motor hole. But I had to make a separate case to connect the remaining motor.
I can not understand why these things were not installed from the beginning
I can not trust this device.
- Tonny
13 Mar 2018 09:01 #68038
by Tonny
Replied by Tonny on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
My iRX-IR8M suddenly displayed the USB logo and it stopped working. Whichever button I press does not respond. Upload VIDEO. Can anyone tell me how to recover?
13 Mar 2018 10:49 #68039
Format transmitter USB drive and copy filesystem from firmware archive:
www.deviationtx.com/forum/builds/7605-ir...uilds?start=20#67668
- Tonny
13 Mar 2018 13:41 #68040
by Tonny
My iRX - IR 8M was revived. Thank you very much.
- Alvarez
15 Mar 2018 14:49 #68091
by Alvarez
You need yo use ibus and the ibus pin on your fc
15 Mar 2018 15:19 #68092
- škrat14
16 Mar 2018 13:28 #68128
by škrat14
Replied by škrat14 on topic iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
Hi my travsmiter irange x locked in usb mode tried everything but nothing happened
please help
please help
16 Mar 2018 14:40 #68133
I need voice mail for this question.
www.deviationtx.com/forum/builds/7605-irangex-irx-ir8m-builds
Time to create page: 1.407 seconds
- iRangeX iRX-IR8M 2.4G 8CH Multi-Protocol
