Devo 7e - timers with throttle starting with -80
- silverAG
17 Jan 2018 00:40 #66918
by silverAG
Devo 7e - timers with throttle starting with -80 was created by silverAG
For some of my whoop quads with silverware, I'm using throttle with offset so my starting point is not -100 but -80 - and I have problems with timers because they start to count when throttle goes from -99 to 0 and above - so timers counts even when my throttle stick is down at -80% and motors are off (motors on my whoops with silverware starts to spin at around -75).
Is there any way I can set timers to work on custom throttle value, like, for example, when throttle pass -75 and not -99?
- gdenton
20 Jan 2018 19:15 - 20 Jan 2018 19:16 #67021
by gdenton
Replied by gdenton on topic Devo 7e - timers with throttle starting with -80
Here's one way to do this:
Set the Timer Switch to a virtual channel.
Edit the virtual channel mixer:
set to Simple
Src = THR
Curve = 9 point
Point 1 = -100
Point 2 = -89
Leave Points 3 thru 9 at 0
This starts my timer @ -74% on a new model file (no trim/offset/throttle curve).
set to Simple
Src = THR
Curve = 9 point
Point 1 = -100
Point 2 = -89
Last edit: 20 Jan 2018 19:16 by gdenton.
- silverAG
22 Jan 2018 08:42 #67038
by silverAG
Replied by silverAG on topic Devo 7e - timers with throttle starting with -80
I tried simmilar trick but I used complex mixer and different points. I'll try this - looks simple and OK.
- silverAG
22 Jan 2018 12:02 - 22 Jan 2018 12:04 #67040
by silverAG
Tried. It works fine! But not with sticky throttle hold
I tried to replace THR with Ch3 as source in Virtual channel because my sticky throttle hold value is -125 at Ch3 - and sticky throttle behaves as expected - when I move stick, Ch3 stays -125 (which is OK and as expected for sticky throttle) but timers are still counting as soon as throttle stick is moved... Of course, virtual channel is assigned to timers...
So I tried to use Ch3 instead THR as input in Virtual channel, but that does not help - looks like Ch3 when used as input in virtual channels still pass original throttle value, and not the one modified by "sticky hold" code.
Strange...
Strange...
Last edit: 22 Jan 2018 12:04 by silverAG.
- gdenton
23 Jan 2018 02:52 #67056
by gdenton
You are right, and I don't think that's the way it should work.
Can one of the devs comment on this please?
silverAG wrote: looks like Ch3 when used as input in virtual channels still pass original throttle value, and not the one modified by "sticky hold" code.
Time to create page: 0.409 seconds
- Devo 7e - timers with throttle starting with -80
