T8SG power on
- Eric B
13 Feb 2018 17:30 #67491
by Eric B
T8SG power on was created by Eric B
When I turn on the transmitter it shows a USB symbol. I have disconnected the battery and tried again with same result. Not sure what to do at this point. I am new to this forum. Transmitter was purchased in Dec 2017 had been using it with a simulator for Liftoff and Freerider. If any other info is needed I can provide. Help
13 Feb 2018 17:36 #67492
Replied by vlad_vy on topic T8SG power on
Most likely transmitter filesystem damaged. You need format Tx USB drive and write filesystem from firmware archive. Use "Safely Remove Hardware" after writing filesystem.
- Eric B
13 Feb 2018 17:41 #67493
by Eric B
Replied by Eric B on topic T8SG power on
Thanks for your quick reply. Not sure how to do what you described... Can you give me a how to for dummies? I am new to this.
13 Feb 2018 18:08 - 14 Feb 2018 05:06 #67496
Inside the battery box you can find mini-USB connector, connect it to computer. For USB mode press ENT and power on transmitter. Format USB drive. The firmware archive you can get at Nightly Builds:
www.deviationtx.com/downloads-new/category/13-nightly-builds
Last edit: 14 Feb 2018 05:06 by vlad_vy.
- Eric B
13 Feb 2018 18:22 #67497
by Eric B
Thanks. What file do I use?
13 Feb 2018 18:35 #67498
Use latest firmware.
www.deviationtx.com/downloads-new/catego...g-v5-0-0-c4ce535-zip
- Eric B
13 Feb 2018 20:53 #67500
by Eric B
Well I Can't seem to get the file to transfer to the transmitter after I unzipped it. Followed your instructions. using windows 10. Frustrated could there be something else wrong with transmitter?
14 Feb 2018 03:46 #67502
Can you format USB drive? What is it capacity?
- Eric B
14 Feb 2018 04:41 #67503
by Eric B
I am unable to format the drive. I can find the transmitter in devices but I can't do anything with it, and I can't find it as a drive, this was tried on 2 different computers.
14 Feb 2018 05:05 - 14 Feb 2018 05:10 #67504
If you can't find USB drive with transmitter at USB mode, probably your transmitter is damaged (flash memory chip SST25VF016B).
Sorry, it is my error: to enable USB mode press ENT and power on transmitter. At your case USB mode always enabled (USB symbol on the screen).
"EXT + power on" = firmware update mode (black screen). Use DfuSe Update tools v2.31 for update firmware.
Last edit: 14 Feb 2018 05:10 by vlad_vy.
- Eric B
14 Feb 2018 05:51 #67507
by Eric B
I finally got the darn thing to show up as a drive. Instead of holding the EXT button when powering on I held the ENT then I could see the drive. The drive was full so reformatted. reloaded and all is well.
Thanks vlad for your help. Is there a protocal for a bugs 3 yet? Again thanks for the help
14 Feb 2018 06:10 #67510
I don't know the protocol state for Bugs 3, see the topic:
www.deviationtx.com/forum/protocol-devel...-bugs-3?limitstart=0
Time to create page: 0.907 seconds
- T8SG power on
