T8SG power on
13 Feb 2018 17:30 #67491 by Eric B
T8SG power on was created by Eric B
When I turn on the transmitter it shows a USB symbol. I have disconnected the battery and tried again with same result. Not sure what to do at this point. I am new to this forum. Transmitter was purchased in Dec 2017 had been using it with a simulator for Liftoff and Freerider. If any other info is needed I can provide. Help
13 Feb 2018 17:36 #67492 by vlad_vy
Replied by vlad_vy on topic T8SG power on
Most likely transmitter filesystem damaged. You need format Tx USB drive and write filesystem from firmware archive. Use "Safely Remove Hardware" after writing filesystem.
13 Feb 2018 17:41 #67493 by Eric B
Replied by Eric B on topic T8SG power on
Thanks for your quick reply. Not sure how to do what you described... Can you give me a how to for dummies? I am new to this.
13 Feb 2018 18:08 - 14 Feb 2018 05:06 #67496 by vlad_vy
Inside the battery box you can find mini-USB connector, connect it to computer. For USB mode press ENT and power on transmitter. Format USB drive. The firmware archive you can get at Nightly Builds:
www.deviationtx.com/downloads-new/category/13-nightly-builds
Last edit: 14 Feb 2018 05:06 by vlad_vy.
13 Feb 2018 18:22 #67497 by Eric B
Thanks. What file do I use?
13 Feb 2018 18:35 #67498 by vlad_vy
13 Feb 2018 20:53 #67500 by Eric B
Well I Can't seem to get the file to transfer to the transmitter after I unzipped it. Followed your instructions. using windows 10. Frustrated could there be something else wrong with transmitter?
14 Feb 2018 03:46 #67502 by vlad_vy
Can you format USB drive? What is it capacity?
14 Feb 2018 04:41 #67503 by Eric B
I am unable to format the drive. I can find the transmitter in devices but I can't do anything with it, and I can't find it as a drive, this was tried on 2 different computers.
14 Feb 2018 05:05 - 14 Feb 2018 05:10 #67504 by vlad_vy
If you can't find USB drive with transmitter at USB mode, probably your transmitter is damaged (flash memory chip SST25VF016B).
Sorry, it is my error: to enable USB mode press ENT and power on transmitter. At your case USB mode always enabled (USB symbol on the screen).
"EXT + power on" = firmware update mode (black screen). Use DfuSe Update tools v2.31 for update firmware.
Last edit: 14 Feb 2018 05:10 by vlad_vy.
14 Feb 2018 05:51 #67507 by Eric B
I finally got the darn thing to show up as a drive. Instead of holding the EXT button when powering on I held the ENT then I could see the drive. The drive was full so reformatted. reloaded and all is well.
Thanks vlad for your help. Is there a protocal for a bugs 3 yet? Again thanks for the help
14 Feb 2018 06:10 #67510 by vlad_vy
I don't know the protocol state for Bugs 3, see the topic:
www.deviationtx.com/forum/protocol-devel...-bugs-3?limitstart=0
Time to create page: 0.181 seconds
