Jumper TS8G plus
09 May 2018 10:57 #69132 by TimmyS
Jumper TS8G plus was created by TimmyS
Hi I am new to multi protocol tranmitters I have just purchased a Jumper TS8G+ to use with my fleet of Indoor aircraft. They are mostly DSM2/DSMX but I have one Ares Fokker Dvii which I am unsure of the protocol required. The information on the TS8G+ says protocol YD717 will run an Ares quad using the Nordic NRF24L01chip can any one help with some advice or point me in the right direction
Tim Scowcroft
09 May 2018 11:03 #69133 by goebish
Replied by goebish on topic Jumper TS8G plus
Just select the YD717 protocol but the only Ares that's been tested is the Ethos QX75 quad, that's not sure the Ares Fokker Dvii airplane is using the same protocol.
09 May 2018 11:09 - 09 May 2018 11:11 #69134 by goebish
Seems the Ares Fokker Dvii comes with an external Rx, some come with an Hitec compatible Rx, maybe this is your case ?
(unfortunately Hitec is not supported by Deviation)
Last edit: 09 May 2018 11:11 by goebish.
09 May 2018 12:34 #69136 by Moeder
Replied by Moeder on topic Jumper TS8G plus
goebish wrote: (unfortunately Hitec is not supported by Deviation)
... yet. Hitec uses cc2500, so implementation is very feasible if anyone is willing to sniff on a tx with a logic analyzer :)
09 May 2018 13:03 #69137 by goebish
Indeed, maybe Pascal is already on it, I'm not sure
github.com/pascallanger/DIY-Multiprotocol-TX-Module/issues/104
Time to create page: 0.900 seconds
