T8SG USB problem
23 Jun 2018 11:37 #69695 by Goochman
T8SG USB problem was created by Goochman
I just purchased a used T8SG and am having a problem connecting it to my PC.
I am new to all of this so hopefully I am just confused.
It’s one of the older models so I took the unit apart connected the USB cable to my PC and to the transmitter.
I turn the transmitter on while holding the enter button and the USB symbol stays on the screen and doesn’t go away and my computer is not recognizing the transmitter.
I bought a brand new micro USB cable.
Is it possible there’s different types of micro USB cables?
Any help is appreciated.
12 Jul 2018 09:43 #69859 by dnlpr
Replied by dnlpr on topic T8SG USB problem
It's not a question of usb cables, that's for sure.
DP
12 Jul 2018 14:53 #69862 by FDR
Replied by FDR on topic T8SG USB problem
I don't agree, the cable might cause problems. I have a few which doesn't work...
12 Jul 2018 17:07 #69863 by Brett_N
Replied by Brett_N on topic T8SG USB problem
Are you trying to upgrade the firmware (bootloader mode?) or add .ini files?
Oh - and you have a battery in the TX right?
You may also need to check for an updated driver. You did download and install DFuse, right?
I use Zadig for drivers. I'll try my jumper when i get home tonight. I know sometimes I have to try different USB ports on occasion.
12 Jul 2018 22:13 #69864 by Goochman
Replied by Goochman on topic T8SG USB problem
I’m trying to upgrade the firmware and install software for different drones but I can’t even get my PC to recognize the jumper
12 Jul 2018 22:15 #69865 by Goochman
I guess I will try another cable and see if that is the problem
13 Jul 2018 04:52 #69867 by vlad_vy
Replied by vlad_vy on topic T8SG USB problem
If you press ENT + Power On, you will get USB mode to access USB filesystem. For firmware upgrade you need press EXT + Power On, then DfuSe can detect transmitter.
13 Jul 2018 10:22 #69868 by Goochman
Ok I’ll give that a try, thanks
17 Jul 2018 23:02 #69894 by Goochman
Thank you guys for your help. I was finally able to get my t8sg to connect to my PC. However I am having an issue installing this--deviation-t8sg-v5.0.0-7867ad5.
I used the DFUSE upgrade tool to install the file in DFU mode with no problem.
I have been watching as many videos as I can and my problem comes when I enter usb mode after installing the firmware in DFU mode.
When I go to the drive for the TX I am not able to delete the existing files. My PC will not delete them.
iIs there another video that explains any of this in more detail?
I totally screwed up what the factory software was on the TX. I just want to be able to wipe it clean and add the new file so I can actually use this controller with the Bugs 3 drone. That is the main reason I bought this controller and I have not been able to use it.
Is there a T8sg instructionally video for dummies?
Any help appreciated.
18 Jul 2018 04:32 - 18 Jul 2018 04:48 #69896 by Ultracon
Replied by Ultracon on topic T8SG USB problem
On my device manager that shows all the USB drives it should be under USB controllers. Also, I had to go to view, and hidden objects, and there it was! You can find the videoon Youtube if you search T8SG failure. There is also a link to the video on the Jumper website, jumperxyz.com, under the manuals and links section. I also posted my fix on my other string "T8SG Plus " Do not download STMicroelectronics" . Lengthy post, step by step, and using the manual as well. And make absolutely certain you are downloading the latest, correct, firmware.
Last edit: 18 Jul 2018 04:48 by Ultracon.
18 Jul 2018 10:24 #69898 by Goochman
OK I’ll look into that thank you
30 Dec 2018 18:09 #72148 by Stevez
Replied by Stevez on topic T8SG USB problem
Good morning, my T8 SG v2 Plus today stopped to work. It show me only a USB symbol and not other..
Unikely my pc told me to formait the radio for use it. I do it as a stupid guy and now nothing run, I dont see no more the USB port in the pc..
Can someone help me to recovery the radio plesae ? (how install the boot-loader, and the radio firmware)
For supply I use a 2 cells lipo battery, if I press EXT + Power-ON the 2 led (red and green) come ON and if I mantain pressed the buttons the USB port appear but I cant use it.
thanks for any help.
30 Dec 2018 18:50 #72150 by hexfet
Replied by hexfet on topic T8SG USB problem
Go to the User Manual link in the left column for Devo 7e/10/12e (similar to t8sg). Follow the directions in the Installation section to do a fresh install of deviation firmware (available in the Downloads link). That should get the tx going as long as it's not a hardware problem.
31 Dec 2018 09:15 - 31 Dec 2018 09:17 #72152 by vlad_vy
If you havn't access to USB drive, try to flash and boot once custom build (t8sg_v2 or t8sg_v2_plus) with bulk USB flash memory erase:
www.deviationtx.com/forum/6-general-disc...-in-usb-mode?start=0
Last edit: 31 Dec 2018 09:17 by vlad_vy.
Time to create page: 0.195 seconds
