Binding FrSky RX impossible
12 Jul 2018 14:23 #69860 by dnlpr
Binding FrSky RX impossible was created by dnlpr
I have 2 receivers FrSky, X8R and G-RX8, already used with a taranis QX7, I want to use them with my T8SG Plus, but the binding does not work, is there a special procedure for FrSky?
Thank you for any answer that can help me.
13 Jul 2018 17:19 #69872 by Ask1me
Replied by Ask1me on topic Binding FrSky RX impossible
same problem here with jumper t8sg v2+
13 Jul 2018 18:10 #69873 by hexfet
Replied by hexfet on topic Binding FrSky RX impossible
For these receivers the deviation protocol to use is FrskyX.
Try binding with the Freq-Fine protocol option set from -127 to +127 in steps of 10.
Bind by powering on the receiver with the F/S button held down, then activate Bind in deviation model setup.
After binding move Freq-Fine up and down to find the max and min values where bind is lost. Leave it set to a value halfway between min and max.
14 Jul 2018 07:48 #69876 by dnlpr
Replied by dnlpr on topic Binding FrSky RX impossible
A big thank you for your answer.
Silly question, I am a beginner with JUMPER, could you tell me how to get Freq-Fine protocol option set?
Thank you
14 Jul 2018 12:16 #69877 by hexfet
To get to protocol options go to the Model setup page, select the protocol button, and press ENT.
16 Jul 2018 06:08 #69884 by dnlpr
Hello, it works! thank you very much for your help.
Time to create page: 0.580 seconds
