Can't bind Mantis 85/Frsky with T8SG
22 Jul 2018 20:57 #69921 by Brian_OH
Can't bind Mantis 85/Frsky with T8SG was created by Brian_OH
I've researched, read and tried just about anything I've found on here and r/c groups that even makes ½ sense and still can't get the critter to bind. I've tried USB, battery, USB and add battery, new battery in Jumper. Tried all the "fine frequency" settings, ADGAIN at 100, changing from UART1 to Uart3 (kinda bound, but controls wrong) switched back (according to manual) Went from original setting of AETR1234 in Betaflight to TAER1234 per manual . . . nothing . . . Manual says it uses TAER but in Betaflight, Frsky in dropdown box says AETR . . . not that either worked anyway . . .
Best luck was with ff set at either -50 or + 70 . . . the green light would go out when i press "Bind" wait about 6 - 8 seconds after binding complete in Jumper, then start blinking again, the other numbers as soon as binding done, light starts blinking again . . .
Bad receiver ????
This is my first BNF and I'm sure not binding and definitely not flying . . .
I don't have the experience with this and don't know what to even try next that would help . . .
AAAAAAAaaaaauuuuuuugh !!!!!!!!!!!!!!!!!!!!
Any ideas would be greatly appreciated . . .
Thanks,
Brian
Time to create page: 0.086 seconds
