How to repair switch on Devo 7e?
13 Aug 2018 22:19 - 13 Aug 2018 22:19 #70237 by silverAG
How to repair switch on Devo 7e? was created by silverAG
Need help :(
Stick from my HOLD switch fell off. Is there a way to repair it and somehow put it back in a hole? Stick has part with spring at the bottom so I assume it need to be pushed in a hole and turned, but nothing I tried works...
Any suggestions or only solution is to replace entire switch?
Last edit: 13 Aug 2018 22:19 by silverAG.
14 Aug 2018 18:48 #70246 by Dashu
Replied by Dashu on topic How to repair switch on Devo 7e?
It should be possible to make a temporary fix, but depends how bad the switch looks like.
It has 2 bent tabs at the bottom. If those tabs are still there and not broken, there is a fix. You need to reassamble the switch and bend the tabs back. Sometimes those bend tabs are not bent properly or they got straight if you hit/put pressure on them (perhaps you drop/hit the remote?)
If not, you could try with a fast curring epoxy. Anyhow the best fix is to replace the switch. It's not expensive, but involves some soldering.
Time to create page: 0.294 seconds
