Frsky R9 module
15 Aug 2018 17:33 #70266 by magic_marty
Frsky R9 module was created by magic_marty
Is it possible to add the Frsky R9 module to Devo transmitters by using the pinout and plugging it to the dsc port on the back of the transmitter? Looking for long range options and thought the R9 might be a good choice...
Thanks all..
<Marty>
15 Aug 2018 20:30 #70268 by Fernandez
Replied by Fernandez on topic Frsky R9 module
Frsky uses PXX serial protocol I beleive.
Hexfet did a good job adding some serial protocols as CRSF and SBUS. topic here: www.deviationtx.com/forum/protocol-devel...al-out-for-lrs-boxes
But Personally I hope some one to hookup logic analyser to it's R900m or Crossfire and deviation to be able to talk to a Semtech module.
16 Aug 2018 02:06 #70274 by hexfet
Replied by hexfet on topic Frsky R9 module
According to this page the R9M JR module accepts both PXX and PPM. Should be able to use it with PPM in deviation. Have not looked at what it would take to add PXX to deviation.
16 Aug 2018 04:11 #70278 by magic_marty
Replied by magic_marty on topic Frsky R9 module
That's good news..So all i should need is the pin out on the module and make up a cord to plug into the DSC port...Then supply the correct voltage to the module ect...
Time to create page: 0.684 seconds
