Jumper T8SG Lite - S-FHss ( RE-INIT )
01 Sep 2018 06:21 #70605 by old4570
Jumper T8SG Lite - S-FHss ( RE-INIT ) was created by old4570
????????????? RE-INIT
S-FHSS / re - init
SO I can't get passed this !
I have 2 quads that are S-FHSS and the transmitter will not go into any sort of Bind Mode .
A) I am doing something glaringly wrong
B) There is some strange Deviation method
C) Something is NQR
These quads work fine on say a XK transmitter , and the other on my Taranis Q x7 with a IRANGEx module .. ( Both quads work fine on my XK transmitter )
07 Sep 2018 15:00 #70723 by Brett_N
Replied by Brett_N on topic Jumper T8SG Lite - S-FHss ( RE-INIT )
When you're in the model configuration screen, does yours show <*FHSS> also? With a big 'ol asterix in front?
I haven't used my jumper in a couple weeks, and all of the sudden, it is acting like it forgot it has a 4:1 radio in it. I have a bunch of foamies on AFHDS-2A and now all I can do is re-init as well. No option to bind. Module is apparently enabled according to my hardware.ini
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
extra-switches = 2x2
extra-switches = potx2
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
;voice=
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
;voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13
07 Sep 2018 15:18 #70724 by Brett_N
OK quick update. I reflashed the latest firmware, then went in through USB and checked my hardware.ini file. I have all of the protocols enabled again.
Interestingly enough, somehow, my T8SG V1 managed to overwrite the harware.ini with a model file.
Here's the fix.
0.5 - Download Notepad++ if you haven't already
1. Unzip the latest build to a new folder
2. Using the latest build and Dfuse, update the firmware
3. Reboot TX, and connect to USB mode
4. right click hardware.ini and make sure it looks like a hardware.ini file. Should look like my above post. If it looks like ANYTHING ELSE, copy the hardware.ini from the unzipped build folder on the PC, replacing the one on the TX.
5. Reboot tx and you should be good to go.
08 Sep 2018 08:24 #70734 by old4570
Replied by old4570 on topic Jumper T8SG Lite - S-FHss ( RE-INIT )
Time for an update ...
I found a youtube video that showed how to bind to a XK251 ...
And this helped me get a bind on my XK251 ...
Though no such luck with my Warlark ..
Not sure how I am going to hold down that bind button long enough to find the offset ...
Time to create page: 0.105 seconds
