Jumper T8SG PLUS stopped working
03 Sep 2018 05:47 #70620 by mercury9
Jumper T8SG PLUS stopped working was created by mercury9
Hello.
I am not good at English.
The red light on the power lamp,
My t8sg plus screen does not turn on.
I can see the usb files on the computer, but the screen is not turned on.
I would appreciate it if you could tell me how to fix it step by step.
03 Sep 2018 07:42 #70622 by goebish
Replied by goebish on topic Jumper T8SG PLUS stopped working
03 Sep 2018 11:38 - 03 Sep 2018 11:39 #70625 by mercury9
Replied by mercury9 on topic Jumper T8SG PLUS stopped working
I appreciated your concerning.
The connection between the computer and the usb mode and the DFU mode is also possible.
There's no picture.
Last edit: 03 Sep 2018 11:39 by mercury9.
03 Sep 2018 13:34 #70626 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG PLUS stopped working
With USB mode try to edit "tx.ini" file and check if "brightness=5" or more.
04 Sep 2018 01:27 - 04 Sep 2018 01:44 #70632 by mercury9
vlad_by
The program installed on my controller is deviation-t8sg_v2_plus-v5.0.0-3bbb8f.
The files are like photos.
There is no "tx.ini" , there is a "tx" file and there is no brightness entry.
Last edit: 04 Sep 2018 01:44 by mercury9.
04 Sep 2018 06:36 #70633 by vlad_vy
It is "tx.ini", but you have "do not show known extensions" option enabled.
My "tx.ini" content:
current_model=1
language=0
music_shutdown=0
mode=2
brightness=5
contrast=5
volume=7
audio_vol=10
vibration=1
power_alarm=10
batt_alarm=7300
batt_critical=3900
batt_warning_interval=10
splash_delay=0
[calibrate1]
max=3179
min=721
zero=2020
[calibrate2]
max=3079
min=884
zero=2043
[calibrate3]
max=3062
min=755
zero=1959
[calibrate4]
max=3204
min=744
zero=2038
[calibrate5]
max=4095
min=0
zero=2047
[calibrate6]
max=4095
min=0
zero=2047
[autodimmer]
timer=20000
dimvalue=1
[countdowntimersettings]
prealerttime=15000
prealertinterval=5000
timeupinterval=2000
[telemetry]
temp=celcius
length=meters
alertinterval=15
04 Sep 2018 07:25 - 04 Sep 2018 07:27 #70637 by mercury9
current_model=1
mode=2
[calibrate1]
;Aileron (Mode 1)
max=3813
min=530
zero=2171
[calibrate2]
;Elevator (Mode 1)
max=3549
min=354
zero=1951
[calibrate3]
;Throttle (Mode 1)
max=3698
min=489
zero=2093
[calibrate4]
;Rudder (Mode 1)
max=3867
min=569
zero=2218
[touch]
xscale=197312
yscale=147271
xoffset=-404
yoffset=-20
Last edit: 04 Sep 2018 07:27 by mercury9.
04 Sep 2018 07:45 #70638 by vlad_vy
So you have default "tx.ini", and by default "brightness=5". It looks like you have some hardware problem. Try reseat LCD flat cable. There is the plastic latch on LCD connector, lift it.
04 Sep 2018 12:14 - 04 Sep 2018 12:28 #70641 by mercury9
I received this product in May.
And it turned on several times, but I can't see the screen.
I sent it to the address that Banggood told me in June, but it was returned to me in August. without even opening
As vlad_by said, if there is a hardware defect, I wonder if you will send lcd.
Last edit: 04 Sep 2018 12:28 by mercury9.
04 Sep 2018 12:51 #70643 by goebish
I would also check if the ribbon cable connecting the display to the main board is properly connected, might be a very simple fix ...
05 Sep 2018 02:09 #70652 by mercury9
The ribbon cable was completely disconnected from the main board and reconnected but the screen was not visible.
07 Sep 2018 17:13 #70727 by Brett_N
Replied by Brett_N on topic Jumper T8SG PLUS stopped working
How did you pay Banggood?
If it was with Paypal, I would start a claim to get your money back. Unfortunately BG customer service isn't always best :-(
Time to create page: 0.103 seconds
