Jumper T8SG Plus V2 - USB format issue
14 Sep 2018 00:00 - 14 Sep 2018 00:01 #70893 by Tang10
Good Day everyone,
I have the problem of I can not format the USB drive. When I format it in windows it starts, but says it can not finish.
Now I'm stuck with a radio that I can't copy the files over.
Any thoughts?
Last edit: 14 Sep 2018 00:01 by Tang10.
14 Sep 2018 06:01 #70894 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG Plus V2 - USB format issue
Try to flash the next build with bulk USB flash memory erase, run it once only, then return to normal build.
www.deviationtx.com/forum/6-general-disc...ck-in-usb-mode#70474
14 Sep 2018 12:47 #70899 by Tang10
Replied by Tang10 on topic Jumper T8SG Plus V2 - USB format issue
Thanks...........I can flash the latest nightly build in defuse Tool.
Do I just use your file in the regular process like loading a night build? Or do a check a box in Defuse Tool that says "Bulk Flash Erase"?
Thanks Again
14 Sep 2018 14:38 #70901 by vlad_vy
Like loading a nightly build.
14 Sep 2018 14:56 #70902 by Tang10
Thanks.........I'll give it a try and report back
14 Sep 2018 22:14 #70903 by Tang10
Sorry guys, but no fix my radio loading the "Bulk USB Flash"
The 2mb SD is messed up I guess
Any good programs to fix USB SD?
Jamie
15 Sep 2018 16:11 #70919 by Tang10
Tried everything I can think of. No possible way to format the SD flash that I have found.
Is the SD part replaceable?
19 Sep 2018 12:37 #70984 by taO
Replied by taO on topic Jumper T8SG Plus V2 - USB format issue
I also had this issue. Maybe this can help you. It solved it for me.
www.deviationtx.com/forum/6-general-disc...lved-at-least-for-me
19 Sep 2018 15:39 #70985 by Tang10
I tried what you said, but no luck for me.
I thinks its garbage from what I can see
22 Sep 2018 01:47 #71006 by Tang10
Any other options for formatting the storage part? 2mb space
I've tried everything
Thanks guys
Jamie
Time to create page: 0.806 seconds
