alternating flashing lights
25 Sep 2018 14:09 - 25 Sep 2018 14:09 #71032 by Tigger
alternating flashing lights was created by Tigger
I am new to deviation and need a bit of help. I recently purchased a T8SG V2 Plus and I have to say I am impressed. So far, it is a great little transmitter. I will add voice shortly and I think it is likely to be my favorite going forward.
I have several planes that I use a standard servo channel to turn leds on and off and cause them to flash. In my Taranis I programed a servo channel to turn on and off at a 1 second interval to make the LEDs flash. Can I do something similar on the T8SG?
Thanks,
Tigger
Last edit: 25 Sep 2018 14:09 by Tigger.
25 Sep 2018 14:19 #71033 by FDR
Replied by FDR on topic alternating flashing lights
Yes you can do it, I use it for a turn signal in a car.
While I don't have that model file at hand ATM, it was based on Fabien's solution, described here:
www.deviationtx.com/forum/7-development/...nerators-to-channels
25 Sep 2018 17:00 - 25 Sep 2018 17:02 #71035 by Tigger
Replied by Tigger on topic alternating flashing lights
And it works perfectly! Very impressive. The only tinkering I had to do was moving the endpoints a bit to make the flash feel good. An easy solution that has a lot of possibilities.
Thank you very much!!!!
Tigger
Last edit: 25 Sep 2018 17:02 by Tigger.
19 Oct 2018 19:49 #71439 by Tigger
For anyone who is interested here is the INI file to make flashing lights on channel 5. The result is a pure square wave and on my jumper the rate is controlled by AUX5. In this INI the three position switch A controls on/off/flashing.
On the model end the receiver is connected to a servo board salvaged from a stripped servo and the servo motor connections drive LED's.
All the credit goes to those referenced in the above posts.
[channel5]
template=complex
[mixer]
src=!Virt1
dest=Ch5
curvetype=min/max
points=0
[virtchan1]
name=Virt1
template=complex
[mixer]
src=AUX5
dest=Virt1
scalar=10
usetrim=0
muxtype=add
curvetype=3point
points=2,53,100
[mixer]
src=AIL
dest=Virt1
switch=Virt2
scalar=0
offset=-100
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Virt1
switch=Virt3
scalar=0
offset=100
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Virt1
switch=SW A0
scalar=-114
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Virt1
switch=SW A1
usetrim=0
curvetype=fixed
[virtchan2]
template=complex
[mixer]
src=Virt1
dest=Virt2
offset=-101
usetrim=0
[mixer]
src=Virt2
dest=Virt2
usetrim=0
curvetype=min/max
points=0
[virtchan3]
template=complex
[mixer]
src=!Virt1
dest=Virt3
offset=-101
usetrim=0
[mixer]
src=Virt3
dest=Virt3
usetrim=0
curvetype=min/max
points=0
Time to create page: 0.499 seconds
