Setting up a Snapper 7 to my Jumper T8SG V2 plus.
29 Oct 2018 06:39 #71501 by Alex007
I received a Snapper 7 with Frsky protocol last week and I am having problems getting it to work with my Jumper T8SG Tx. I have got it bound and an arming switch setup. My problem is that when armed the Throttle stick when pushed up gets the props to just twitch a bit. If I move the Aileron stick to the right 2 of the motors start up and if I move it to the left the other two motors start up. When I first connected it to Betaflight on the receiver page the channel map was set to TAER1234 and I changed it to AETR1234 which is how all my other quads are setup with my Jumper and also how I have seen it setup on a few Youtube tutorials.
I have checked the mixer settings on the Jumper and everything seems to be setup as normal.
Does anyone have any suggestions?.
30 Oct 2018 01:51 #71504 by hexfet
The channel monitor will show what the t8sg is sending on each channel. That should match what you see on the receiver page in betaflight configurator.
Time to create page: 0.057 seconds
