Devo 10 CC2500 failed
- Danker16
08 Nov 2018 01:53 #71636
by Danker16
Devo 10 CC2500 failed was created by Danker16
hello,
I have been using my devo 10 with an added cc2500 module for over a year. however today I was flying my helicopter on Frsky protocol. took a break powered up the tx and nothing. the model setup page shows *Frsky..meaning there is no module available... I dont even get a missing module message.
i redid all my solder joints but nothing...
any ideas?
any ideas?
- goebish
- NRF Weirdo
09 Nov 2018 11:43 - 09 Nov 2018 11:49 #71672
by goebish
Replied by goebish on topic Devo 10 CC2500 failed
First check with a multimeter that the module has proper power supply between DVDD (Vcc) and Gnd (+3.3V) then try to connect the CSn pin to another GPIO (A13, A14 ...), don't forget to modify hardware.ini accordingly.
If it still doesn't work maybe your CC2500 is defective.
Last edit: 09 Nov 2018 11:49 by goebish.
- Danker16
10 Nov 2018 07:28 #71705
by Danker16
Replied by Danker16 on topic Devo 10 CC2500 failed
nope, tried all that nothing... i hope my radio didnt break in some way
- goebish
- NRF Weirdo
10 Nov 2018 10:54 - 10 Nov 2018 14:31 #71707
by goebish
Can you try with another Protocol / Rx that's not using the CC2500 ?
If it works then your SPI bus is fine, and the problem comes from the CC2500 module.
Last edit: 10 Nov 2018 14:31 by goebish.
- Danker16
10 Nov 2018 17:45 #71713
by Danker16
yea dsmx works on the walkera chip.
- Danker16
14 Nov 2018 01:26 #71749
by Danker16
bought a 4-1 module. all back to normal now
Time to create page: 0.496 seconds
- Devo 10 CC2500 failed
