Jumpert8sg plus trims
- 1942keremeos
18 Nov 2018 21:32 #71797
by 1942keremeos
Jumpert8sg plus trims was created by 1942keremeos
Trying to trim an airplane in the air is next to impossible. Moving the trim switch one way or the other the servo hardly moves,how do I get more movement?
- Fernandez
18 Nov 2018 21:43 - 18 Nov 2018 21:44 #71798
by Fernandez
Replied by Fernandez on topic Jumpert8sg plus trims
You have to adjust the trim step size, by default it is very (too) small steps for me...(Especially to dial in a new plane....)
Also take care, to verify trim switches they are assigned to the designated channels, I had made a mistake once.....
Last edit: 18 Nov 2018 21:44 by Fernandez.
- 1942keremeos
18 Nov 2018 22:10 #71801
by 1942keremeos
Replied by 1942keremeos on topic Jumpert8sg plus trims
Thanks for your reply Fernandez,I'm not very familiar with deviation I find it difficult to used to turnegey.If you could tell me how to do that I would be the happiest guy on the planet.lol.
- 1942keremeos
19 Nov 2018 23:18 #71819
by 1942keremeos
Found how to change trim steps but they only work on high rates. Wonder why deviation is so user unfriendly. Things that should be easy aren't.
Time to create page: 0.218 seconds
- Jumpert8sg plus trims
