Jumper T8SG V2 Plus strange problem
- Suter
05 Dec 2018 05:59 #71987
by Suter
Jumper T8SG V2 Plus strange problem was created by Suter
I have had very strange occurrence which so far I have not been able to resolve.
It just happened, the following are the symptoms that I have noticed so far.
On Main Page
Trim RV:- Works correctly when pulling down
Trim RV:- on short up activates a timer. Left enter arrow stops timer
Right enter arrow starts time. Timer has been set off Throttle stick as countdown
No timers reset switches have been allocated
Trim RV:- on long up activates GPS
Trim RH:- On short to the left is normal
Trim RH:- On long to left activates both LH Aileron Trim and Up throttle trim together
Trim RH :- to the right cycles thru the Main Menu
Trim LV:- will travel both up and down on short press and long press
Trim LH:- seems normal
To try to fix this I have flashed the Nightly Build that I have been using, and transferred all the models back and the problem remains
I hope someone has an idea about this one it does seem strange.
Cheers
Will Suter
On Main Page
Cheers
Will Suter
- Suter
10 Dec 2018 21:45 #72043
by Suter
Replied by Suter on topic Jumper T8SG V2 Plus strange problem
I realize that my post is very long winded and probably difficult to understand.
It is hard to describe the symptoms with words
It would probably be easier to analyze with a video.
Attached is a video which hopefully shows my problem.
To me it appears to be a Transmitter Hardware failure.
10 Dec 2018 23:30 #72045
Replied by hexfet on topic Jumper T8SG V2 Plus strange problem
Yes, it seems consistent with a problem with one or more of the
button matrix
connections. Check the processor pins for shorts or poor solder joints.
Time to create page: 0.050 seconds
- Jumper T8SG V2 Plus strange problem
