FrSky R9 Mini 4/16CH 900MHz
- DJDavid33
07 Dec 2018 11:26 #72000
by DJDavid33
FrSky R9 Mini 4/16CH 900MHz was created by DJDavid33
Hello I bought a RX FrSky R9 Mini 4 / 16CH 900MHz
but is it compatible with my Devo 10 I have the module 4 In 1 and the firmware Nightly Builds FrSkyX I have so far all my RX frsky works.
what to do as a modification on the radio if needed and what firmware Nightly Builds is needed? thank you
- Fernandez
07 Dec 2018 12:05 #72001
by Fernandez
Replied by Fernandez on topic FrSky R9 Mini 4/16CH 900MHz
Hexfet is doing some good works on the serial protocols!
Currently you could hook up a Frsky R9M or R9 lite Transmission module via trainer port ppm. Hopefully soon we do have PXX working.
Maybe in the future some of the RF guru's here, at some point hook up a Semtech RF module via SPI to Deviation...….but for now is not the case.
- DJDavid33
07 Dec 2018 12:56 #72004
by DJDavid33
Replied by DJDavid33 on topic FrSky R9 Mini 4/16CH 900MHz
Thanks for your help. if I understand correctly I have to buy a module frsky R9M?
Time to create page: 0.396 seconds
- FrSky R9 Mini 4/16CH 900MHz
