jumper T8SG and voice
25 Dec 2018 17:27 #72114 by ALF26540
jumper T8SG and voice was created by ALF26540
hello
i just installed the dfplayer module and i made the soft modifications described in the tutorial (followed to the letter)
or on my radio it appears in the voice menu: 'external voice currently not avaible'
will I have to forget something?
thanks for your help
26 Dec 2018 03:03 #72117 by hexfet
Replied by hexfet on topic jumper T8SG and voice
I just installed the dfplayer in t8sg v2 plus following the instructions in the wiki and everything worked fine. Recheck your file changes and voice.ini and SD card mp3 directory.
09 Jan 2019 08:55 #72248 by ALF26540
Replied by ALF26540 on topic jumper T8SG and voice
problem solved. in the firm there are 2 lines voice and in the topic it is not said to delete one. now everything works
26 Jan 2019 23:06 #72562 by spacecase
Replied by spacecase on topic jumper T8SG and voice
Pardon me but Im having similar issues.
I cant see my DFPlayer usb drive after I soldered it in, was worried I missed some pins.
I can only see my Transmitter usb drive. Not a separate one for the SD card. Is there anything you need to do other then format the card and have the mp3 folder on it?
27 Jan 2019 00:03 #72565 by hexfet
The dfplayer doesn't show up as a drive. There's no circuitry for that. Some folks add a second usb connector wired directly to the dfplayer.
Load the files on the SD card with a PC.
27 Jan 2019 04:11 #72570 by spacecase
Sweet baby Jesus it worked. Thank you so much!. Just is a file source.
Deleting the ; for uart5 and coping voice.ini into media folder on transmitter were the hard part.
This is a wonderful site.
Time to create page: 0.268 seconds
