jumper T8SG and voice
- ALF26540
25 Dec 2018 17:27 #72114
by ALF26540
jumper T8SG and voice was created by ALF26540
hello
i just installed the dfplayer module and i made the soft modifications described in the tutorial (followed to the letter)
or on my radio it appears in the voice menu: 'external voice currently not avaible'
will I have to forget something?
thanks for your help
26 Dec 2018 03:03 #72117
Replied by hexfet on topic jumper T8SG and voice
I just installed the dfplayer in t8sg v2 plus following the instructions in the wiki and everything worked fine. Recheck your file changes and voice.ini and SD card mp3 directory.
- ALF26540
09 Jan 2019 08:55 #72248
by ALF26540
Replied by ALF26540 on topic jumper T8SG and voice
problem solved. in the firm there are 2 lines voice and in the topic it is not said to delete one. now everything works
- spacecase
26 Jan 2019 23:06 #72562
by spacecase
Replied by spacecase on topic jumper T8SG and voice
Pardon me but Im having similar issues.
I cant see my DFPlayer usb drive after I soldered it in, was worried I missed some pins.
I can only see my Transmitter usb drive. Not a separate one for the SD card. Is there anything you need to do other then format the card and have the mp3 folder on it?
27 Jan 2019 00:03 #72565
The dfplayer doesn't show up as a drive. There's no circuitry for that. Some folks add a second usb connector wired directly to the dfplayer.
Load the files on the SD card with a PC.
- spacecase
27 Jan 2019 04:11 #72570
by spacecase
Sweet baby Jesus it worked. Thank you so much!. Just is a file source.
Deleting the ; for uart5 and coping voice.ini into media folder on transmitter were the hard part.
This is a wonderful site.
Time to create page: 0.097 seconds
- jumper T8SG and voice
