Spektrum AR410 Not Binding
24 Feb 2019 17:20 #73001 by kingstar
Spektrum AR410 Not Binding was created by kingstar
I am super new to the hobby. I have a Devo 7e that I installed the deviation firmware on. I have used it successfully with a lemon Rx satellite. I am building a tiny trainer and purchased the Spektrum AR410 from flitetest for it. I've connected the ESC BEC to the AR410 (both battery connection or servo 1 tried) and pressed the button to start the binding process. Also tried holding bind button while connecting battery. In my devo, I created a new model, set it to dsmx (tried dsm2 as well), set channels to 4, and hit bind. I can't get it to bind. The light just continues to flash endlessly. A few times it actually stopped rapidly flashing, blinked 4(?) times, and then went out. Manual says it should go to a solid light. Also, the motor doesn't play any sounds when I plug in ESC. Not sure if it should. I'm super frustrated at this point and could use some help if anyone has some ideas.
25 Feb 2019 06:10 #73005 by vlad_vy
Replied by vlad_vy on topic Spektrum AR410 Not Binding
Try to set 8 channels mode.
