Migrating from 3.0 to 5.0
- OrbitalGolem
01 Apr 2019 01:43 #73651
by OrbitalGolem
Migrating from 3.0 to 5.0 was created by OrbitalGolem
I'm finally migrating to Deviation 5.0 with a new transmitter after many thousands of successful flights with 3.0.
My needs are simple - I only use DSMX and DSM2 with Spektrum, Orange, and Lemon satellites. No telemetry. I fly helis only. I use Devo 8S and 12S transmitters. No glitches ever with 3.0. I also want the old GUI.
Would the 5.0 release from 2016 be suitable? Were there any DSMX issues that a follow-up version addressed? 3.0 worked perfectly with the receivers above.
Thanks in advance and keep up the awesome work.
01 Apr 2019 05:21 - 01 Apr 2019 05:28 #73655
Replied by vlad_vy on topic Migrating from 3.0 to 5.0
I recommend you to use v5.0.0 release custom build with latest protocols integrated. Also, it has some fixes and improved GUI redraw. Nightly builds right now have massive changes and not quite stable.
www.deviationtx.com/forum/builds/6407-de...cols?start=460#73210
Last edit: 01 Apr 2019 05:28 by vlad_vy.
- OrbitalGolem
01 Apr 2019 14:43 - 01 Apr 2019 14:45 #73660
by OrbitalGolem
Replied by OrbitalGolem on topic Migrating from 3.0 to 5.0
Many thanks for the reply Vlad - very helpful.
If I've already installed v5.0.0 release, do I need to re-flash with an updated DFU or will copying the filesystem suffice?
What are the XMS files?
Last edit: 01 Apr 2019 14:45 by OrbitalGolem.
01 Apr 2019 15:06 - 01 Apr 2019 15:15 #73661
You need flash updated DFU and update filesystem files.
XMS files are for modded transmitter with bigger flash memory chip (USB drive). You can read about it:
www.deviationtx.com/forum/builds/6861-ul...-devof12e-xms-builds
devo12-XMS version don't use DFU library and all filesystem files placed on USB drive, as for devo8.
Last edit: 01 Apr 2019 15:15 by vlad_vy.
Time to create page: 0.687 seconds
- Migrating from 3.0 to 5.0
