Scale throttle based on wheel
- EDU.WES
06 Apr 2019 19:34 #73714
by EDU.WES
Scale throttle based on wheel was created by EDU.WES
Anyone know how to scale throttle based on one of the transmitter wheels. For example %50 on this wheel would scale throttle %50. There are videos showing the OpenTX setup but not seeing Deviation yet
07 Apr 2019 03:54 #73716
Replied by hexfet on topic Scale throttle based on wheel
Use a complex mixer. Set it up however you like for normal throttle control. Then add one more mixer. On that page set Src to the wheel you want to use, and set the Mux to mult. With a 1-to-1 curve putting the wheet at 100% gives 100% of the throttle mix. Wheel at 0% (midpoint) kills throttle completely.
- EDU.WES
07 Apr 2019 16:33 #73720
by EDU.WES
Replied by EDU.WES on topic Scale throttle based on wheel
Close, it’s scaling the top of the throttle like I want but it’s also scaling the bottom of the throttle. At the top of the wheel I have normal -100 to +100 range. At slightly lower than top of wheel I have -80 to +80 instead of the needed -100 to +80
- EDU.WES
07 Apr 2019 16:43 #73721
by EDU.WES
Think I found it, I changed to min instead of mult. Now I always have -100 but the top end gets scaledEDU.WES wrote: Close, it’s scaling the top of the throttle like I want but it’s also scaling the bottom of the throttle. At the top of the wheel I have normal -100 to +100 range. At slightly lower than top of wheel I have -80 to +80 instead of the needed -100 to +80
- EDU.WES
07 Apr 2019 16:46 #73722
by EDU.WES
Never mind, that plain cuts it off instead of scaling it
08 Apr 2019 04:33 - 08 Apr 2019 04:53 #73732
Replied by vlad_vy on topic Scale throttle based on wheel
I think you need scale "mult" mux from 0 to +100%. Offset = 50, Scale =50. If you need different scaling, adjust Offset and Scale to proper values.
For example, if you need 30% to 100% scale, Offset = 65, Scale = 35.
Last edit: 08 Apr 2019 04:53 by vlad_vy.
- EDU.WES
09 Apr 2019 01:33 - 09 Apr 2019 01:39 #73741
by EDU.WES
Can’t get it to work, not sure what I’m doing. The OpenTx version has you add another mixer with Add and scale 50 offset -50 but that’s not doing it
Last edit: 09 Apr 2019 01:39 by EDU.WES.
Time to create page: 0.419 seconds
- Scale throttle based on wheel
