HELP!DEVO8s No Throttle Just ESC Beeping
- DevoNub
07 Aug 2019 06:14 #74836
by DevoNub
HELP!DEVO8s No Throttle Just ESC Beeping was created by DevoNub
Hi Guys,
I'm new here so hoping someone can help me or point me in the right direction.
I have a Devo8s with the Deviation firmware installed, currently using Devo and DSMX protocol receiver.
The receiver binds great with the transmitter and all the servos work but the issue is that their is no throttle and the ESC doesn't arm and keeps on beeping.
I have used it one two different airplane models one Walkera Reciver and the other DSMX both yielding the same results.
Few thing that i have tired too trouble shoot:
1. Lowering the throttle trim all the way down
2. increasing the throttle to max position so the ESC arms
3 Also read through the manual quite a bit with no success
Thank you in advance, any comments or recommendations is welcomed
- propnut
07 Aug 2019 16:53 #74837
by propnut
Replied by propnut on topic HELP!DEVO8s No Throttle Just ESC Beeping
Have you tried putting a normal servo on the THR channel to see if that moves as expected. Could be something as simple as your throttle channel needs reversing or perhaps your ESC is shot. You don't say whether you used the same ESC in both your models.
- DevoNub
09 Aug 2019 05:06 - 09 Aug 2019 05:07 #74846
by DevoNub
Replied by DevoNub on topic HELP!DEVO8s No Throttle Just ESC Beeping
Hi Propnut,
Thank you for your response!
I actual tried putting a servo on the throttle and it works fine also attempted to reverse it with no luck.
I have tried it with two different ESC's.
Last edit: 09 Aug 2019 05:07 by DevoNub.
- propnut
09 Aug 2019 05:52 #74847
by propnut
If the servo works then it sounds like you need to calibrate your ESC so it knows the range of the radio. If not calibrated it will still be seeing low throttle as being higher than it really is and for safety reasons won't arm. Read the manual of your ESC to see how this is done. Otherwise you could play with the scale settings of your throttle channel to increase the end point throws but calibrating the ESC would be my preferred route.
- DevoNub
10 Aug 2019 06:32 #74851
by DevoNub
Awesome it finally woks, thank you for your help propnut.
I've been trying to figure this out for the past 2 weeks.
thanks again
thanks again
Time to create page: 0.150 seconds
- HELP!DEVO8s No Throttle Just ESC Beeping
