Devo7e Blade 200SRX binding problem.
- bxz
07 Aug 2019 18:13 #74838
by bxz
Devo7e Blade 200SRX binding problem. was created by bxz
Hi, I tried 2 ini files for the 200SRX on devo 7e, both have the same symptom. I'm not sure what's going on.
After binding, the receiver is blinking, that's solid when I use the Blade transmitter. And although i can control the heli using the 7e, the servo movement is stuttering and delayed. I'm guessing this is more like a binding issue than the ini file issue? I wish i could attach the video file.
thx in advance.
thx in advance.
- bxz
08 Aug 2019 13:46 #74842
by bxz
Replied by bxz on topic Devo7e Blade 200SRX binding problem.
OK, i actually found the problem. Somehow on the devo 7e I have to use DSM2 instead. Using DSMX causing the problem, the AR636 uses DSMX as i recall.
- gdenton
08 Aug 2019 23:10 #74845
by gdenton
Replied by gdenton on topic Devo7e Blade 200SRX binding problem.
That's strange, mine binds/flies fine with DSMX.
I recently had the servo stuttering/delayed response when binding an Eflite F-15, found it was caused by not having one of the channels at the expected value while binding.
Time to create page: 0.033 seconds
- Devo7e Blade 200SRX binding problem.
