4.01 to 5 upgrade issue, Bad/or missing protocol
- Frieda
06 Oct 2019 20:40 #75193
by Frieda
4.01 to 5 upgrade issue, Bad/or missing protocol was created by Frieda
Hi Everyone,
I was upgrading from 4.0.01 on the 7E, and ran smack into the Bad/or missing protocol error. To fix, I deleted the version 5 protocols, and then reintroduced the 4.0.01 protocols. I had essentially copied all files, as per the readme.
This doesn't seem proper to me. Any comments / help would be greatly appreciated. Do I need to start over? I have no extra modules, and only one model so no concerns about wiping everything clean.
I am just using USBHID right now, so not in any kind of panic.
Cheers, Freida
Cheers, Freida
07 Oct 2019 04:14 - 07 Oct 2019 04:18 #75197
Replied by vlad_vy on topic 4.01 to 5 upgrade issue, Bad/or missing protocol
What firmware release do you use? Try to use:
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75159
or
www.deviationtx.com/forum/builds/8508-re...ild-deviation-v5-x-x
At any case with devo7e you need update at least firmware along with 'protocol' folder. Will better completely rewrite the filesystem. Backup used model files, after update write model files back to filesystem.
or
Last edit: 07 Oct 2019 04:18 by vlad_vy.
- Frieda
07 Oct 2019 05:17 #75202
by Frieda
Replied by Frieda on topic 4.01 to 5 upgrade issue, Bad/or missing protocol
Hi vlad_vy,
I used deviation-devo7e-v5.0.0-28ce50f. I thought I didn't need to do the 'upgrade firmware' step, thinking this wasn't required? All I did, was to copy all the files over.
I originally installed deviation 4.01 several years back. And, I had forgotten all the steps to install the FW. I thought the UPDATING readme, says I just need to copy the files.
Sometimes these technical documents can be a challenge to follow.
07 Oct 2019 05:23 #75203
I think current nightly builds can be problematic for devo7e (and other transmitters), I suggest to use any of above builds.
- Frieda
07 Oct 2019 12:41 #75204
by Frieda
Ok thanks vlad_vy,
I will follow your suggestion.
Cheers.
Cheers.
Time to create page: 1.197 seconds
- 4.01 to 5 upgrade issue, Bad/or missing protocol
