A7105 not able to bind with flysky - eachine 010s
10 Oct 2019 20:21 #75214 by pattap
Hi all
I new to flying RC so bear with me.
I have recently purchased eachine 010s that has A7105 transceiver. I think it did bind initially, side green LED's would react to controller movement but I wasn't able to arm the drone. I have connected it to cleanflight no problems but then I have decided to connect a battery at the same time which I believe cause issues I'm having now. Binding LED instead of being blue.
Is there are way of checking whether a7105 got damaged?
15 Oct 2019 06:14 #75262 by propnut
IT probably didn't arm because you didn't set the ARM switch correctly or the throttle range in Betaflight.
Time to create page: 0.036 seconds
