T8SG V2 Plus, changing enter for back button
30 Dec 2019 13:48 #75638 by Fernandez
Hi Maybe it is me, but i can't get used to the button layout on TGSG plus V2, it feels unnatural inconvenient.
I would like the lowest bigger button leftside as the "enter" and the smaller button above as "back, so basically the back button and enter button function to be swapped.
Is there a way to do it?
02 Jan 2020 22:31 #75651 by eried
For temporal fix you could edit github.com/DeviationTX/deviation/blob/ma..._t8sg_buttonmatrix.h and recompile. For most permanent solution I guess you could add a new setting for the firmware.
03 Jan 2020 17:16 #75656 by Fernandez
Replied by Fernandez on topic T8SG V2 Plus, changing enter for back button
I am not good in coding, I hope some one could code it.
so if this line is present, in hardware.ini, it will apply, otherwise will work normal.
swapped back/return button = enabled
04 Jan 2020 23:32 #75661 by eried
You don't really need to code anything, just replace the enter by back in that list in any text editor and follow the instructions to compile it in docker.
I dont know if anyone besides you would find that feature useful enough to add it to the official and clutter the config.
Time to create page: 0.218 seconds
