T8SG V2 Plus, changing enter for back button
- Fernandez
30 Dec 2019 13:48 #75638
by Fernandez
T8SG V2 Plus, changing enter for back button was created by Fernandez
Hi Maybe it is me, but i can't get used to the button layout on TGSG plus V2, it feels unnatural inconvenient.
I would like the lowest bigger button leftside as the "enter" and the smaller button above as "back, so basically the back button and enter button function to be swapped.
Is there a way to do it?
- eried
02 Jan 2020 22:31 #75651
by eried
Replied by eried on topic T8SG V2 Plus, changing enter for back button
For temporal fix you could edit
github.com/DeviationTX/deviation/blob/ma..._t8sg_buttonmatrix.h
and recompile. For most permanent solution I guess you could add a new setting for the firmware.
- Fernandez
03 Jan 2020 17:16 #75656
by Fernandez
Replied by Fernandez on topic T8SG V2 Plus, changing enter for back button
I am not good in coding, I hope some one could code it.
so if this line is present, in hardware.ini, it will apply, otherwise will work normal.
swapped back/return button = enabled
- eried
04 Jan 2020 23:32 #75661
by eried
You don't really need to code anything, just replace the enter by back in that list in any text editor and follow the instructions to compile it in docker.
I dont know if anyone besides you would find that feature useful enough to add it to the official and clutter the config.
Time to create page: 0.180 seconds
- T8SG V2 Plus, changing enter for back button
