What advantages to upgrade FW?
- JohnBee
15 Jan 2020 05:37 #75723
by JohnBee
What advantages to upgrade FW? was created by JohnBee
I own a DEVO 12S and have never upgraded anything since I purchased in shortly after it hit the shelves and have only used it a few times after purchasing it, as I lost interest in flying Helicopters.
With that said, I would like to get back into the flying by starting with some smaller indoor heli's then working my way up to a 700 class.
Would I benefit from flashing a new FW into the radio?
The about on the radio read as follows;
Hardware Ver. 1.0
Software Ver. 1.5
Library Ver 1.0.8
Hardware Ver. 1.0
Software Ver. 1.5
Library Ver 1.0.8
- JohnBee
15 Jan 2020 08:37 #75725
by JohnBee
Replied by JohnBee on topic What advantages to upgrade FW?
Okay I did the update (I think), but there's something funky going-on with my radio.
When it starts-up there a message stating channel 3 is 98% safe, no clue what that means, then I touch the screen and it closes
Following this, the system boots to a screen with a Heli icon, where there's a tool icon at the left, though it doesn't seem to be responding to touch.
Also radio appears to be bleeping on regular intervals, no clue why, whereas none of the screen functions appear to be responding.
Anyone got any ideas as to what's going on?
- JohnBee
15 Jan 2020 10:59 #75727
by JohnBee
Just to update, I managed to return the FW back to stock - and everything is back to normal.
With that said, and in the event that someone else is looking to go down the same path, I would caution against it, as the Deveation 5.0 update for the DEVO 12S does not seem functional in it's current state.
- Mack775
16 Jan 2020 23:18 #75737
by Mack775
Replied by Mack775 on topic What advantages to upgrade FW?
www.deviationtx.com/forum/builds/6407-de...-protocols?start=480
For the update file. The devo 12s has to be flashed 2 times firmware
firmware dfu fash firmware tab lib.dfu under the library tab. And the screen calibrated and the sticks calibrated.
been using deviation on my 12s for quite sometime and it does work. But to get the full benefit you need to install devo 4 in 1 module.
- Mack775
16 Jan 2020 23:24 #75738
by Mack775
And I have 3 devo 12s and all work on deviation and 4 in 1 module !!
- -=Hubi-Dirk=-
18 Jan 2020 13:52 #75746
by -=Hubi-Dirk=-
It is not responsible to change a firmware on a remote control without first having thoroughly familiarized yourself with the firmware. Especially when using 700 class helicopters. For this you can find a manual and many answers in this forum to your questions.
With the Deviation firmware I have been operating many different models for many years, today I have 23 models. I have had many different remote controls, but my Devo 12s with Deviation is the best combination I have had so far.
1st tip: Warnings from the throttle channel should be taken very seriously.
2nd tip: Read the manual.
Replied by -=Hubi-Dirk=- on topic What advantages to upgrade FW?
JohnBee wrote: Just to update, I managed to return the FW back to stock - and everything is back to normal.
- JohnBee
20 Jan 2020 08:51 #75766
by JohnBee
Just to update(again...), I have since ordered a Jumper T16 Pro radio and have decided to retire my DEVO 12s
And while I would love to be able to say it served me well, I cannot, as I have barely used it all of two times since I purchased it - and that's on me entirely.
Therefore and if anyone is interested in a like new DEVO 12s with metal case and accessories such as; opened/unused receiver, strap, spare battery, remote connectors for flight-sim etc. please don't hesitate to contact me.
Otherwise, the unit will go in storage until it is no longer viable - which is a terrible waist really
Beyond that, I'm really stoked with the T16 Pro, which seems very well made, and fully open Tx compliant, which is a feature that I have been wanting for some time, but was not ready to the pay the premium for.
- Mack775
20 Jan 2020 10:57 #75770
by Mack775
Just bought a new blade chroma drone my hobby budget gone. If you still have it later maybe try. Mack
- JohnBee
20 Jan 2020 11:00 #75771
by JohnBee
I've been contemplating a price, do you think it's worth 100 dollars?
Sure, and thanks for responding.Mack775 wrote: Just bought a new blade chroma drone my hobby budget gone. If you still have it later maybe try. Mack
- Mack775
20 Jan 2020 11:04 #75772
by Mack775
Yes I do
- JohnBee
20 Jan 2020 11:05 - 20 Jan 2020 11:06 #75773
by JohnBee
Whatever the case, it beats rotting in a storage bin.
Cool. I'd be satisfied with thatMack775 wrote: Yes I do
Last edit: 20 Jan 2020 11:06 by JohnBee.
- Mack775
20 Jan 2020 11:43 #75774
by Mack775
Where are you from
- JohnBee
20 Jan 2020 11:43 #75775
by JohnBee
I'm located in Newfoundland Canada
- Mack775
20 Jan 2020 11:51 #75777
by Mack775
Like New that is a bargain!
- Mack775
21 Jan 2020 12:38 #75789
by Mack775
If you sill have it in a couple of weeks I will see if I can't work that into my budget.
- JohnBee
21 Jan 2020 14:41 #75790
by JohnBee
No worries, whenever is convenient for you.
Time to create page: 0.293 seconds
- What advantages to upgrade FW?
