jumper t8sg V3 carbono
27 Apr 2020 15:02 #76208 by roso
jumper t8sg V3 carbono was created by roso
trying to help those like me who have updated JUMPER T8SG v2 PLUS.
and are having problems.
the problem is easy to solve.
1- we buy jumper V3 and not 2 plus or any other ...
2- it is sad that here in the forum there is no v3 to download ...
3- I can give a link to whoever needs it ... below I leave an image of how my jumper was.
espero ajudar
03 May 2020 08:47 #76219 by eried
Replied by eried on topic jumper t8sg V3 carbono
Is it V3 real? Does it say V3 in the box or case?
03 May 2020 16:04 #76221 by roso
Replied by roso on topic jumper t8sg V3 carbono
that's the problem.
it doesn't say anywhere, just on the website and it says V3.
who updated, will give shit ...
solution and update with this Version: deviation-t8sg_v2-v5.0.0-1c43d1b.zip only with this I solved my problem ....
I know it says V2 but this zip. and only for TS8G CARBON VERSION ,,, not with oled display. OK...
04 May 2020 08:32 #76223 by eried
Nice. Have you tried the voice in the v3? does it has the same glitches as v2? (when it starts it says "saving, saving, saving")
05 May 2020 03:51 #76224 by pcrane87
Replied by pcrane87 on topic jumper t8sg V3 carbono
i am having the same problem where is that file located at I when throw all the downloads can you paste the link on here.
15 May 2020 17:54 #76318 by cerox
Replied by cerox on topic jumper t8sg V3 carbono
I bought a T8SG V2 plus carbon and I've got problem with the display, the text is inversed and switch to 180°. I open the remote and on the motherbord it is writed "T8SG V3 plus".
What version of firmware should I install in it ?
15 May 2020 23:39 #76322 by roso
instale do site jumper
www.jumper-rc.com/
18 May 2020 03:16 - 18 May 2020 17:20 #76329 by ramunas
Replied by ramunas on topic jumper t8sg V3 carbono
Vlad answered the questions of correct firmware download in some previous posts. The only difference between the T8SG V2 and the T8SG V2-Plus firmware is the screen display. V2 for the LCD screen (white background with black text). V2-Plus is for OLED screen (black background with white text). The V3 board did not need any firmware update - so use the correct V2 download for the screen you have. The original T8SG V2-Plus had an OLED screen - that is why the "Plus" firmware is associated with the OLED. Unfortunately the OLED screen is poor in sunlight, so most recent manufacturers are putting the LCD screen in the boxes that are labeled "Plus". So if you have an LCD screen use the T8SG V2 firmware even if the box has a Plus label. No harm if you loaded the wrong firmware - you just can't read the display. Files can be found under "Downloads" in the Main Menu above - use the nightly builds.
Last edit: 18 May 2020 17:20 by ramunas. Reason: spelling,
16 Oct 2020 11:47 #76882 by Skillin
Replied by Skillin on topic jumper t8sg V3 carbono
Have same prob guted as was looking forward to useing it help plz
Time to create page: 0.503 seconds
