Help me set up the hardware!!!
- yaKOS
30 May 2020 18:37 #76384
by yaKOS
Help me set up the hardware!!! was created by yaKOS
Connect the transmitter and open the removable device that you mentioned.
Copy the attached .ini-file in the folder: /models/
You will now find a new model named "usb" in the List of models at position 6 (according to the file-name).
( model menu -> model setup -> load )
Select this model and your computer should recognize the Transmitter as a USB Game-Controller.
- Волошин
31 May 2020 20:04 #76401
by Волошин
Replied by Волошин on topic Help me set up the hardware!!!
It doesn't open on your computer as a removable device(
01 Jun 2020 04:24 #76404
Replied by vlad_vy on topic Help me set up the hardware!!!
What transmitter do you use?
Try format transmitter USB drive with "Quick Format" option enabled. If you can't format and you use T8SG series, try to flash latest nightly builds and use "USB drive erase" procedure:
www.deviationtx.com/forum/builds/8656-t8...rmat-usb-drive#75915
Time to create page: 0.155 seconds
- Help me set up the hardware!!!
