T8sg v2 plus. Crossfire work.
- ravageur
21 Jul 2020 11:38 #76597
by ravageur
T8sg v2 plus. Crossfire work. was created by ravageur
i had many hard hours yrying to makes crossfire working..
If you install the micro crossfire module for the jr bay, you need to have the right power in transmitter first..
I had the 4 aa battery tray with 50% used batteres. It was not enough to powering the crossfire module.. it was making noise like a short corcuit and was always shutting down the transmitter.
So i used a 2s battery. First problem solved.
The transmitter and crossfire module need to be upgrade to the latest version..
T8sg v2 plus oled need t8sg v2 plus firmware.
T8sg v2 plus lcd need t8sg v2 firmware.
On both you need to do the 1st and 5th pin interconnection and removing the upper pin.(there is a post for this)
You need to bind the receveir to the crossfire module first. This can be done with pc and tbs agent software. You just need to powering the receiver.
Then choosing crfs protocole in transmitter.
Betaflight...... select the right protocol in configuration tab.. activate the telemetry.
Activate serial rx in ports tab on uart 6 (where my receiver is connect)
Usually it suppose to work at this step.
There is also a cli command line for rx inverted if it still no working.
It now work reallu well for me.
I also have configuration fonction for crossfire in the transmitter.
I will add info if need.
- yammahoppy
31 Aug 2020 15:26 #76738
by yammahoppy
Replied by yammahoppy on topic T8sg v2 plus. Crossfire work.
Question regarding the solder pads. Did you just solder a wire between the solder pads or from the solder pads to the pin 1. Not sure where the solder wire needs to go. A photo would be nice if you have the time...
Thanks......
Thanks......
- ravageur
01 Sep 2020 10:12 #76743
by ravageur
Replied by ravageur on topic T8sg v2 plus. Crossfire work.
When back cover is remove and the transmitter is stand up (antenna up) pin 1 is the higher one.. 4 is the lower one.
This video will help you
- ravageur
01 Sep 2020 21:40 #76746
by ravageur
Time to create page: 0.296 seconds
- T8sg v2 plus. Crossfire work.
